Fan Shroud?
Old Jul 12, 2011 | 08:51 AM
Wyatt66f100's Avatar
Wyatt66f100
Fan Shroud?
Im looking to get a fan shroud installed in my 66 f100. ive got a 64 thuder bird 390 in it on truck perches. also it has a aftermarket flex fan. what have you guys used for shrouds? is there something i can get from a junkyard? have you guys fabbed your own?
Old Jul 12, 2011 | 10:58 AM
PA74F250's Avatar
PA74F250
It depends what size your radiator is but I know the ones from later trucks work too. We have used those and a few other things from the 73-79 trucks.
Old Jul 12, 2011 | 12:04 PM
OldHarley's Avatar
OldHarley
Wyatt,
Your truck did not come with a shroud, but the D3TZ8146C shroud from 67-76 F100-350 will fit if it is an all stock FE V8, however, I'm not sure about sizes of the aftermarket flex fans, though.
The shroud can also be bought new from several vendors, I think you will find new prices range from $67. to $100.
BTW my rad supports do not have the pre-drilled shroud holes, although I understand some do.
Also, one member fabbed a shroud from a piece of flexible black plastic garden edging Do a search for that one .
Old Jul 12, 2011 | 06:44 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by OldHarley
Your truck did not come with a shroud, but the D3TZ-8146-C shroud from 67-76 F100-350 will fit if it is an all stock FE V8, however, I'm not sure about sizes of the aftermarket flex fans, though.
The shroud can also be bought new from several vendors (if they still have any). I think you will find new prices range from $67. to $100.
Bad newz: Ford just obsoleted D3TZ-8146-C (replaced C8TZ-8146-K). Marked on the upper left hand corner: C8TA-8146-S or D3TA-8146-DA
FoMoCo raised the prices a coupla months before they obsoleted the puppy, so don't expect to buy one (if you can find one) for $67-$100. / Last MSRP: $141.60 / Dealer net cost: $84.96.
A year or so ago, this puppy had an MSRP of about $100.00.
There are exactly two sources that have one each of these shrouds, one is in Puerto Rico. No other FoMoCo Dealer or obsolete parts vendor has any.
This fan shrouds original applications were: 1967 F100/350 352 & 1968/76 F100/350 360/390 with Standard, Xtra Cooling and A/C radiators. Not used (will not fit) with 1967/76 optional Super Cooling radiator.
The Super Cooling radiator is almost 5" taller than the other radiators, uses a specific radiator support that has a larger opening radius.
The D3TZ-8146-C fan shroud is a "bolt on" for 1965/66 F100/350's. I added a new one to my 1965 in 1981, fit like it was made for it. I also installed a 4 row radiator at the same time.
A member bought one for his 1964 F100 292, said it bolted right on.
Old Jul 17, 2011 | 06:50 PM
Wyatt66f100
I think i have a later model radiator installed now as well. i think its from the 70's model year. it mounts with 4 bolts and 4 nuts on the core support from flanges on the radiator. I have a reciept from a radiator shop when it was last pressure tested and cleaned in 1985. I may have to just take a picture of my fan and shround and take my camera with me to the yard and see if anything matches up. that is if i can find my camera.
82f-100
20
Feb 10, 2026 06:52 PM
str8patina
Mar 15, 2020 10:20 AM
Jim and Austin
16
Oct 6, 2016 05:49 PM
KRDiesel
Oct 20, 2012 06:34 PM
badfl97
2004 - 2008 F150
Mar 21, 2010 12:03 AM
