Sponsored by: Auxito
No Power Under Load
Old Jul 20, 2011 | 12:49 PM
Bluegrass 7's Avatar
Bluegrass 7
Look at the fuel regulator hose by removing it to see if there is any signs of gas in the hose.
If yes, the regulator diaphram is allowing gas to flow direct into the intake and flood the engine.
Otherwise, the injectors are pulsed at cranking time. If igniton fails the engine will load up with gas.
Normally to clear it, floor the throttle to shut off fuel injection and crank a mimute to so to clear the cylinders. If there is ignition it should attempt to fire when it clears enough.
Good luck.
Old Jul 23, 2011 | 07:17 AM
allen62's Avatar
allen62
It does try to fire like that. I even tried spraying fuel up the throttlebody and it also tried to start like that. Thinking it my b in the Ecm. Got a new one in gonna take it to for to get it programmed then they can tell me if there was something wrong with my old one. Hopefully there isnt and it is something small.
Old Nov 7, 2018 | 04:26 PM
Derek04F150lar's Avatar
Derek04F150lar
Originally Posted by Bluegrass 7
Your at a point that it needs to be looked at with a scanner full time to see what happens when it dies.
The scanner should trap the conditions at time of failure and offer a lead as to what the failure involved.
It's hard to help much more from afar behind a key board.
I did this for 30+ years from drawings and telephone, helping techs who had the same info to look at, out of a jam with other types of very large systems, so that is what I try to do here as the only way I might be of assistance.
Only difference here is the owners usually are not techs so I have to steer them in the most basic ways by suggestion and example. Sometime it works sometime not.
The help depends very greatly on accurate discription and honest feedback otherwise it's the old saying 'garbage in garbage out' result.
Good luck to you.
Bluegrass 7 are you available still could really use some help w my 07 4.6 f150
Old Nov 7, 2018 | 05:46 PM
Bluegrass 7
allen, if it's a flooding condition why would you spray even more fuel through the throttle body?
If the plugs are wet with fuel they won't fire the gas.
You have to establish whether or not this is the case so you know what your chasing.
Why pay out for an ECM before you know what's going on? It's just expensive guessing.
If he motor fires at all it's not the ECM.
Old Nov 7, 2018 | 11:12 PM
Lime1GT's Avatar
Lime1GT
Is it possible a shorted radio capacitor on the front of the engine could cause this problem?
Old Nov 8, 2018 | 12:25 AM
Bluegrass 7
The capacitor is from 12 volt battery to ground on a circuit that feeds both the coils and the injectors.
I would believe a fuse would blow under that circumstance!
Don Gor
Oct 15, 2018 11:19 AM
Don Gor
New Member Introductions
Sep 20, 2016 02:17 PM
Graggk
1997 - 2003 F150
Sep 7, 2016 07:04 PM
ethanw191
2004 - 2008 F150
Nov 16, 2014 10:57 AM
tattooed_yoshi
May 20, 2013 03:37 PM
