Sponsored by: Real Truck
Fog Light issue
Old Jul 11, 2011 | 07:40 PM
n7bsn's Avatar
n7bsn
Fog Light issue
I have a new (to me) 2008 F350 SC-LB-DWR Lariat. It has what appears to be the factory fog lights, the light switch has both the pull-out function and the marking to imply it has factory fog lights. Only they don't work, nor does any indicator light inside the truck. Reading the manual the only fuse I see listed is the inside fuse (#21) for relay that is tied to both the fog lights and corner lights. I'm guessing there is another fuse, but where? Did I miss something reading the section three times? I figure if both lamps were burned out, the indicator should still light TTFN Ralph
Old Jul 12, 2011 | 08:06 AM
1973Ford2004's Avatar
1973Ford2004
I have an '04 I had to replace that whole switch assembly 2-3 years ago, it's easy to pull out you might want to check and make sure the electrical connectors are still plugged in the back, do your headlights work? My fog light bulbs haven't burned out yet 115,000 miles. My switch you turn to fog light and pull out sounds the same with yours? The truck has to be running and they only work on low beam, but the indicator light should be on regardless. Good Luck
Old Jul 12, 2011 | 07:11 PM
n7bsn's Avatar
n7bsn
Loose connection on the switch...TTFN
F.X.5
Nov 30, 2015 04:06 PM
jman228
Apr 10, 2015 08:44 AM
hasteranger
Nov 25, 2014 10:57 PM
Jmatthews
Jan 5, 2014 02:23 PM
FKNVA
Electrical Systems/Wiring
Nov 21, 2002 07:47 PM
