Crazy coil wont shut off
Old 07-11-2011, 04:49 PM
kilog69's Avatar
kilog69
kilog69 is offline
Help My 1992 F150 ,is making me crazy . Coil fires like a Tig tourch, i have never seen this before .It died right after i started it .i have replacrd coil. dis, pick up. and tryed a module form a mustang. mustang mod slowed down sparks . but it will fire non stop when key is on.Checked all fuses and relays . Anybody ever have this happen before?
Old 07-12-2011, 07:03 AM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,167 Likes on 922 Posts
What was the series of events that lead up to this issue? Were any parts changed before this happened? What about any rewiring or other accessories added?
The only way to fire a coil is to apply voltage to the positive side then release the energy by momentarily grounding the negative side. Something has to be acting as a "chopper" circuit to continuously fire off that coil without the engine turning over.
Old 07-12-2011, 08:09 AM
subford's Avatar
subford
subford is offline
When something impossible is happening then 99% of the time it is a bad ground someplace.
Old 07-12-2011, 08:53 AM
kilog69's Avatar
kilog69
kilog69 is offline
First thanks 2 ,RLA2005 & subford. nothing has been changed recently. I suspect it has something to do with a streering coloum swap that my brouther did for me as i have a very bad back. when this happend i smelled a wire buring smell ,opened hood disconneted batt. searched all wireing and fuses found no burnt wires or blown fuses.but did find alot of sloppy work done by my bro. ive been working on cars trucks tractors gas and diesel for over 40 years. i will have to take dash apart to look further i think that were the trouble is.Truck is in between my 2 garages so a have only a short time to work before my back puts me down or the heat this time of year in so. Fl. im going to winch it up on car carrier and put inside today i hope.I have never seen a coil fire non stop before ,i did not think it was poss. Thanks again.
Old 07-12-2011, 10:23 AM
rla2005's Avatar
rla2005
I was chasing the circuit that supplies voltage to that circuit. It does get routed through the ignition switch.
Old 07-12-2011, 10:26 AM
subford's Avatar
subford
subford is offline
An arcing Ignition switch or the Ignition Switch plug can cause it to do that.
hockeyguy1134
11-12-2013 11:50 AM
hazer
06-01-2013 07:58 PM
Henry Carter
08-17-2010 11:26 AM
460429_freak
4 Cylinder Engines
04-09-2008 05:59 PM
Fomoko1
06-18-2005 11:22 AM
Quick Reply: Crazy coil wont shut off
