Sunpro Tach Install
Old Jul 11, 2011 | 11:42 AM
puroford's Avatar
puroford
Sunpro Tach Install
Hello,
I am installing a Sunpro Tach. The instructions are pretty straight forward but I just want to be sure.
I grounded the black wire to a bolt in the engine bay.
I hooked up the green wire to the - side to coil
I hooked the white wire to my other guages for the lighting
The red one was hooked up to the yellow power wire coming from behind the ignition switch.
Do yall agree with this wiring?
Old Jul 11, 2011 | 11:49 AM
BossFan's Avatar
BossFan
I literally just did this exact install yesterday on my 1978 F250 and followed the same basic wiring. I have a 1984 351W in the truck, so I just tapped into the Tach Test wire in the harness. I also found a switched 12V source as well. The one thing that I didn't do right was I tapped into the headlight wiring harness for the light on the tach, except the light only works when I put the lights on and when I switch to high-beams, I lose light. I am going back into the harness to find the instrument panel lights.
Frank
Old Jul 11, 2011 | 12:13 PM
puroford's Avatar
puroford
I see, i used the roof light wiring for my lights on my guages, they only cut on when the lights are on, but it works for me
Old Jul 11, 2011 | 01:05 PM
jsutton's Avatar
jsutton
Frank
Tie into the wiring for the bulb that is on the left of the dash panel that lights up the display for the lights and windshield wipers. Very easy to find.
Old Jul 11, 2011 | 03:28 PM
wyckedcombo17's Avatar
wyckedcombo17
x2 on the bulb for behind the windshield wiper/headlight switch for the white wire for the lights.
I don't agree on the red wire though. For that one, there is a yellow harness that hangs in the dash behind the headlight switch. It is a 12v switched, and you can connect to it with a bullet connector on your red wire. Don't mess with the wires that lead to the tumbler if you can help it.
Old Jul 11, 2011 | 04:03 PM
puroford's Avatar
puroford
Wycked,
Agreed, i will have to look for that wire. I was hesitant to put it there also but went ahead to see it run.
Old Jul 11, 2011 | 04:54 PM
NW 150's Avatar
NW 150
yep that should do it
Old Jul 11, 2011 | 11:37 PM
wyckedcombo17
No problem! This is what it looks like. It's the yellow harness with 3 female bullet connectors. It has a black wire with a green stripe going into it. In this picture, my red gauge wire is coming out of it.
Old Jul 13, 2011 | 08:25 AM
puroford's Avatar
puroford
Wycked,
Thank you for that picture. I will make sure to tap into that wire. Is this connection just hanging around? Can i use this for more than one 12v source since it looks like it has three outputs?
Last edited by puroford; Jul 13, 2011 at 02:23 PM. Reason: added words to clear up the statement
Old May 1, 2017 | 02:28 PM
LeviD's Avatar
LeviD
I know this is an old thread, but can someone tell me where the green wire is for the distributor?
Old May 1, 2017 | 02:46 PM
Filthy Beast's Avatar
Filthy Beast
Not sure if I understand yer question but on the DSII, a green/white stripe wire goes to the TACH TEST horseshoe connection on the coil.....from the loom. The distributor has a three wire connection - orange, purple and black
Old May 1, 2017 | 03:12 PM
LeviD's Avatar
LeviD
I don't know why I said distributor in my last post. I mean the wire that goes to the coil. Wondering is someone has a picture of where this wire splices in?
Old May 1, 2017 | 03:20 PM
Filthy Beast
If you're looking to hook up a tach...(as the thread title suggests)...you can wire the tach to the neg (-) connection on the coil.
If you're looking for where the G/w wire splices into the loom from the coil, give me a few and I'll go look at an old (haha) harness....but I think it runs into the ICM and another 4 prong plug harness....
Old May 1, 2017 | 03:34 PM
Filthy Beast
Can't give you a picture...but - the G/w 16 ga wire from the coil's TACH TEST runs into the loom that houses the oil sending unit wire (and some others)......over to the ICM area. The ICM has a rectangular connection - R/g, R/w, etc and next to that is a circular 4 connection dealie. The 16ga G/w wire connects opposite to a solid, light Green, 18 ga wire.....then runs into the cab. From there.........?
Hope this helps/is what you wanted...
Old May 1, 2017 | 03:36 PM
LeviD's Avatar
LeviD
Oh so I don't have to splice it anywhere? Just connect it to that, then connect the other wires as stated in the original post?
