No experience with the system on a 300 motor but I have done some research and have found very little info. I have the Clifford mani and I am trying to decide if I need the injection. I need to know if it offers much over the carbs for 2x the money, my application will be a puffed up stock motor and no real cold weather use. I see you have asked the same thing over at fordsixperformance. I have not called Redline yet but may soon. If you do call and find anything out let us know.
Well i have called several times. Just to see if it is legit on the product they are selling. But overall the gain over the carbs Lary says is so minima you will hardly notice. He says that it almost isn't worth it unless you just have the money to spend.
So if you have the money and time go ahead. If not than just carb and tune and boom done.
I have looked for the same info and found most truck guys are not willing to spend the money for the carbs/mani let alone the throttle bodies. Also most hot rodders think its ludicrous to put an inline in a hot rod. Thanks for the info you supplied.
