Easy Oil Question
Old Jul 10, 2011 | 08:30 PM
bkenc's Avatar
bkenc
Trailering
Easy Oil Question
OK went into Wal-Mart for some oil. Tired of changing every 3K miles in my 2005 6.0 diesel, so purchased some 10-40W full synthetic. Realize I should be using 15-40W but will it really make a difference? Any motor issues using synthetic? Thanks in advance for a response.
Old Jul 10, 2011 | 08:41 PM
zhilton's Avatar
zhilton
The truck will be fine on the 10W40. You don't have to change the oil every 3k miles. Ford claims you can go 7500; but most folks are doing it at 5k miles since the oil gets sheared pretty hard...it's trashed before you get to 7500 miles.
bismic's Avatar
bismic
What oil did you get? Is it CI4 or CJ4 rated?
Old Jul 10, 2011 | 08:42 PM
bkenc's Avatar
bkenc
Trailering
Thanks, just wanted to make sure.
Old Jul 10, 2011 | 08:44 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
And make sure you have the right oil filter to go along with it.
Motorcraft FL-2016
Racor PFL-2016
Ford 6.0 Liter Turbo Diesel Truck Filters, Air Filters, Oil Filters, Transmission Filters And Glow Plugs - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
Old Jul 10, 2011 | 08:46 PM
bkenc's Avatar
bkenc
Trailering
Doesn't say anything about CI4 or CJ4 rated, just ACEA, A3,API, SN SL rated. So is this OK?
Old Jul 10, 2011 | 08:47 PM
amdriven2liv
Pick up the Rotella T6 synthetic. It's good and rated accordingly.
Sells at Wal-Mart
Old Jul 10, 2011 | 08:51 PM
bkenc's Avatar
bkenc
Trailering
So the Mobil I 10W-40W is not the right type of synthetic? I didn't see the T6.
Old Jul 10, 2011 | 08:58 PM
bismic's Avatar
bismic
Not if it isn't CI4 or CJ4 rated.
Diesel engines need diesel oil - to deal with the soot and potential acid formation.
Mobil 1 makes a GREAT synthetic 5W40 diesel oil.
I use the Rotella T6 also.
Old Jul 10, 2011 | 08:59 PM
johnthoms's Avatar
johnthoms
Sounds like mobil 1 for gas engines. The correct type of oils for are trucks are diesel specific oils,they encapsulate the soot that diesels make much more of than a gas motor. I would highly recommend using cj4 or ci4 rated oils and not take a chance our 6.0 are really tough on oil, seems I have had better starting and smoother idles since I switched to Rotella t-6 full syn great stuff
Old Jul 10, 2011 | 09:01 PM
bkenc's Avatar
bkenc
Trailering
Wow, sure glad I asked the question. My first diesel and still learning. Thanks all!
Old Jul 10, 2011 | 09:15 PM
ljutic ss's Avatar
ljutic ss
You purchased gas engine oil, don't use it in your truck.
Old Jul 10, 2011 | 09:31 PM
johnthoms's Avatar
johnthoms
Yea diesel only oils and OEM FILTERS can't stress this enough almost didn't catch local shop I had change the oil a few times and always look under hood when ever I get work done and saw new oil filter cap , looked closer and saw carguest in injet on side guickly informed my shop and they just shuruged and said didn't think it mattered.
Oh boy does it matter!!
Old Jul 10, 2011 | 09:41 PM
bkenc's Avatar
bkenc
Trailering
I'll take the Mobil stuff back and hope Wally World has the T6. Thanks.
Old Jul 10, 2011 | 10:08 PM
zhilton's Avatar
zhilton
I forgot to ask in my first reply if the oil was CJ4 or CI4 rated...good catch there Mark. You most definitely want to make sure it's rated for one of those two. Sorry about that.
