Sponsored by: Auxito
Transmission
Old Jul 10, 2011 | 07:24 PM
davidjsee1's Avatar
davidjsee1
Transmission
Afternoon all. My 97 F150 with 185,000 and the 4R70W 4 speed auto transmission starts to shake like I'm running over speed bumps while I'm driving down the street. It usually happens around 35 MPH it happens, but not all the time. It seems to shift fine, and this truck is in very good shape. Then engine is strong, and I don't think it's the engine since the tach is smooth.
The trans fluid is bright red, any ideas???
Thanks
Old Jul 16, 2011 | 12:04 AM
noshowbo's Avatar
noshowbo
i am having exactly the same problem and my i have babied my truck for years. Going to have fluid and filter change Monday. just hard to believe it is Transmission, never had any problems with this truck, only 77,000 miles. Any suggestions.. Help!
Old Jul 16, 2011 | 12:18 AM
Bluegrass 7's Avatar
Bluegrass 7
Does it exibit this at light throttle applications then clears if downshifted and rpm rises at greater throttle openings?
Old Jul 16, 2011 | 09:37 AM
noshowbo's Avatar
noshowbo
Yes, please tell me what you think..
Old Jul 16, 2011 | 09:40 AM
noshowbo's Avatar
noshowbo
If I hold the throttle very light at around 20-30 mpr its really noticable..
Old Jul 16, 2011 | 05:16 PM
Bluegrass 7
I would suspect a coil fault if other items have been ruled out.
The use of a Scanner to trap the fault in real time would be very helpfull.
Good luck.
Old Jul 16, 2011 | 10:12 PM
noshowbo's Avatar
noshowbo
Thanks, I will check out coils
fordpstroke11
2009 - 2014 F150
22
Jan 11, 2015 05:24 PM
Fastfwd
Jun 27, 2014 07:21 PM
mrdjc99
Dec 27, 2012 01:40 AM
CAMiniTruck
Jun 12, 2011 11:58 AM
mofordfome
Nov 21, 2004 08:38 PM
