brake controller question
Old Jul 10, 2011 | 11:35 AM
michael cook's Avatar
michael cook
I was wondering if anybody has put an aftermarket controller on your 2011 Mine does not work I put in the fuses and relay did you have any trouble getting your to work mine was plug and play???
Old Jul 10, 2011 | 12:11 PM
powerstroke72's Avatar
powerstroke72
There's a sticky at the top of the forum here about this. You'll need to take your truck to the dealer to get it flashed to work with the truck, if I recall correctly. Here's a link:
https://www.ford-trucks.com/forums/1...l-09-f150.html
Old Jul 10, 2011 | 03:24 PM
danmactrucking's Avatar
danmactrucking
You have to take it to the dealer to finish the project. About 5 minutes with the computer and it will work just fine.
Dan
Old Jul 11, 2011 | 03:36 AM
michael cook
bbbbbb
even with the afermarket ones the computer needs to be flashed???
Old Jul 11, 2011 | 05:42 AM
powerstroke72
Sorry....my bad. I was in a hurry yesterday and didn't notice the "aftermarket" part of your post. That being the case, I'm not sure why it wouldn't work. I know of no reason then, that the dealer would have to flash it. Is the controller not functioning or do you just not have power to it?
Old Jul 11, 2011 | 06:31 AM
michael cook
bbbbbbb
I have power to it but it does not put power to brakes or register on digital readout I added the factory 7 prong plug because my truck only came with the 4prong but all 7 patterns should be standard the brakes on the trailer work with my 2006 just fine.
Old Jul 11, 2011 | 09:29 AM
danmactrucking
Did you connect it to the rewired under the dash?
Old Jul 11, 2011 | 03:38 PM
blueovelboy's Avatar
blueovelboy
good question,
there where a few things the OP said that concern me like where did you hook up the 7 pin plug to? and that you didn't have a tow pkg from factory so how sure are you all the wiring is there, did you check it?
Old Jul 11, 2011 | 08:16 PM
michael cook
brake
I bought the factory plug that had the 7 and 4 prong from the dealer it plugged in in the back where the 4 plug was plugged in then bought a controller then plugged in under dash into factory plug then put in the fuse and relay any ideas
Old Jul 12, 2011 | 12:13 AM
blueovelboy
if you pluged in the four pin in the back of your 7 pin then thats the problem.
am i just not getting what your saying?
or did you conect the plug where the 4 pin came from?
sorry i have had one beer to much ill look at this in the AM. ok
Old Jul 12, 2011 | 02:55 AM
michael cook
brake
plugged the new 7 and 4 into the wiring harness under the rear of truck where the original 4 plug harness was plugged in
Old Jul 12, 2011 | 06:24 AM
danmactrucking
What did you connect the controller to under the dash. I bought an aftermarket controller, but itonly had 4 wires coming out and the connection under the dash had 7. I went to ford and bought the in dash one and installed and then had it flashed. Does your truck have the tow/haul mode?
Old Jul 12, 2011 | 03:33 PM
michael cook
brake
yes my truck has the tow haul mode but I can't put in a factory in dash unit because my truck did not come with the factory tow package I added the hitch and the 7/4 prong plug then bought aftermarket controler with the plug in for the 2011 f150 so I can understand whats wrong
Old Jul 12, 2011 | 03:42 PM
RV_Tech's Avatar
RV_Tech
Catch me up a sec. First can you tell me what controller you bought? I know it doesn't make any difference but I need to be on the same page you are.
Steve
Old Jul 12, 2011 | 03:46 PM
danmactrucking
Dies your truck have the plug under the dash for a brake controller? It will be a little white connector with seven wires going into it. I'm just thinking that even though you didn't get a towing package the wiring might ne there.
