2004 Ford Bed Rails
Old Jul 9, 2011 | 09:21 PM
LionsfaninIowa's Avatar
LionsfaninIowa
2004 Ford Bed Rails
Hello everyone I own a 2004 F150 . I recently moved from the desert and want to know if there is a product out there that can restore the black plastic rails along my bed. I have talked to a few people and decided that painting them is not an option. I live in the midwest now and want to put life back in the truck. Thanks
Old Jul 9, 2011 | 10:47 PM
ReAX's Avatar
ReAX
Being black, you do have an option or two. Mother's makes a product called "Back to Black" (Meguires probably has an eqv) I would start with that. I've had pretty good luck using back to black and then dressing it with a protectant (Mother's again, but Meg should have something too.) If that doesn't give you the results you want Bondo has a product and there is Forever Black. I've tried the Forever Black with pretty good results. I haven't tried bondo's stuff because I haven't had the need to after the Forever Black.
Old Jul 10, 2011 | 11:32 AM
LionsfaninIowa
Thank you for the advice. Ill let you know the results.
Old Jul 22, 2011 | 05:44 PM
Sputz's Avatar
Sputz
my bed rails and also the cowling in front of the windshield both have turned grey from the years of UV exposure - oddly the plastic base of the antenna still looks new - anyway, I tried the "Back to Black" and it didn't make a difference. I suppose I could mask everything off and try painting with a plastic style paint (Rust-O-Leum has a new product) - anyone else have any luck with a cleaner?
Old Jul 23, 2011 | 08:05 AM
ReAX's Avatar
ReAX
I would suggest trying the forever black or the bondo gel stuff first. It's going to be a bit less messy than spray painting.
Old Jul 23, 2011 | 01:02 PM
Sputz's Avatar
Sputz
I agree that painting would involve a lot of prep - I was at WalMart this morning and bought a bottle of Turtle Wax Trim Restorer --it works great - especially the cowl at the base of the windshield. Hope it will last...
Old Aug 10, 2011 | 03:34 PM
dtingle89's Avatar
dtingle89
the heat gun trick would outlast the polish restorers, if you have a steady hand. i did it to my 04 f150 and so far it has lasted 5 months in a hot 99 degree alabama summer
search the forums in 2004-2008 f150s, $9-15 for the heat gun is well worth it and will outlast byfar
Old Aug 10, 2011 | 03:36 PM
dtingle89's Avatar
dtingle89
the restorers would wash off after a while and wear away fast in weather, but yes never paint that type of plastic, it will peel eventually, no matter how good of a job it was
Old Oct 9, 2011 | 04:08 PM
SCBarger's Avatar
SCBarger
The heat method works really well. I just bought a 2004 and the worst thing about it was those rails. It took me 15 minutes with a plumbing torch and they where back to black. If you use a torch just keep it moving and not to stay in one spot to long. I am sure this is going to last the longest out of all because it is melting the plastic so before they ash up again the plastic has to oxidize again.
Johnpsz
Mar 17, 2017 10:41 PM
FLARESIDEDADDY94
Florida Chapter
May 25, 2016 03:14 PM
z28jimi
Feb 21, 2016 06:19 AM
Fastback460
May 4, 2015 07:02 PM
skidj0003
2004 - 2008 F150
15
Feb 9, 2004 05:51 PM
