Coolant level low
Old Jul 10, 2011 | 07:54 PM
onuredneck707's Avatar
onuredneck707
Upon further inspection, I am not sure that I have lost any coolant. It was a tad below the min line. I am wondering if this could be due to the leveling kit I installed though and now the coolant would be shifted back in the bottle causing it to look like it actually has less in it. At any rate, I added just a bit, maybe one cup or so to get it to the bottom of the min line. This eased my mind. Now I just need to order my parts for the oil cooler replacement.
By the way, the Scangauge did not pick up the code. I think it has something to do with the type of code it was. I read on here that they don't pick up wrench light codes but do read CEL codes. Maybe I am wrong though. If you figure it out, please let me know. Thanks for all the help guys!
Old Jul 11, 2011 | 11:38 AM
Carolina Rig's Avatar
Carolina Rig
The coolant level in my truck, and a lot of 6.0s, will settle in about 1" - 1.5" below the FULL mark on the degas bottle.
If I fill mine up to the mark, it'll work its way back down to about 1.25" below the mark on the bottle after a day of driving. I've marked that spot with a Sharpie and it doesn't deviate - it's about 1.25" below the factory mark on the bottle.
Not saying you don't have a leak, but it more than likely won't stay at the FULL level as indicated on the degas bottle when there are no leaks in the system.
I use Zerex G05.
Old Jul 12, 2011 | 07:04 AM
onuredneck707
Perfect. That helps a lot. Thanks!
Old Jul 12, 2011 | 11:45 AM
jdadamsjr's Avatar
jdadamsjr
And there was a tsb a while back where ford just put a new decal on the degas bottle to show the 'NEW' Min and Max marks...
my max ended up about where the old min was
Old Jul 12, 2011 | 12:31 PM
69cj's Avatar
69cj
That tsb came out in 2005.
Old Jul 12, 2011 | 09:34 PM
jdadamsjr's Avatar
jdadamsjr
then that certainly is defined as a while back
joejackF250
May 17, 2016 04:05 PM
jpcjguy
May 21, 2015 07:59 AM
f150crewcab
Mar 29, 2015 11:48 AM
Kongerup
Feb 2, 2015 11:26 AM
madhatt
Feb 25, 2014 04:30 PM
