1966 - 1977 Early Broncos
Bronco ??'s
Old Jul 9, 2011 | 09:36 AM
shockman's Avatar
shockman
Bronco ??'s
Just acquired what I believe to be a 1970 Bronco, came with a cabin I bought at the lake, was used for pushing logs off the beach and launching boat. Has not been on the road for many years. Starts fine and runs good but shakes like a leaf when over 20mph, is rusted pretty good. My ? is what size is the I 6cyl engine and are these worth rebuilding, what to look for as expensive parts. What about replacement panels etc.
Old Jul 9, 2011 | 10:55 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Should be a 170ci inline 6. Shaking, I would check the entire steering assembly. Have someone turn the wheel while you look for any play indicating worn out bushing etc. Also the driveline for worn U joints. Replacement panels are readily available. Engine is very durable, but I would upgrade to a 200ci engine before I rebuilt a 170. The 200 came stock in 73-74. Mustangs, Granada's, Fairmonts and a few others also used the 200ci.
Old Jul 9, 2011 | 03:18 PM
tomf1230's Avatar
tomf1230
Why do you want to rebuild the engine if it starts fine & runs good? I agree with the other reply, the engine shouldn't be causing the shaking. Does it smoke?
As far as parts, it depends on what it needs...front/rear end, tranny etc. rebuilds can get pricey, but aren't needed often. Parts are easy to find. Bronco vendors, ebay, classicbroncos.com has a very good classified section, but be careful on ebay. People get parts from vendors or even auto parts stores & overcharge for them, especially when shipping is added. Ebay is hit/miss for parts. Look on craigslist too. Is there anything you're looking at in particular?
Old Jul 10, 2011 | 09:16 AM
shockman's Avatar
shockman
Thanks for the reply's, not too worried about the engine, seems to run quite well and have lots of mechanical experience on engines. I'm more concerned about body and power train, suspect the shakeing to be u joints, will get it up on blocks when I have a chance and see how rusted the frame is and a better look at body panels to see how much work would be required. Will also check out classicbroncos.com
Old Jul 11, 2011 | 09:13 PM
chrlsful's Avatar
chrlsful
I hope 16 posts is not too late for me 2 welcome U to our forum (and site)! Hope U stick around, lotta helpful guys on here. U can also join ur local Chapter for (non-cyber) real boots-on-the-ground contact w/local FTEers. Don't C ur name or location on the posts but there may B bronks close (more certain re: ford trucks).
(watch out, some pretty big egos over there)
broncofix, broncoHQ, broncos, pirate 4X4, lonestar etc etc (all dot com).
boy, there's a few there (drive shafts themselves) but w/o more details it's tough to Dx.
panels
can u tin knock (I used the tin roof offa the chicken shed roof)
rebuild
why? my '70 has got me around for 28 yrs OK, I see some supprising goop in the radiator reciently & a stain down the block starting @ the head gasket but it's got several hundred thous mi on it. What tells U that a rebuild is needed? With the 411 rear it still pulls great! Bettern 20 mi p/gal...
idealtrucks
1978 - 1996 Big Bronco
Jul 23, 2010 07:45 PM
Red Ford Truck
Ontario Chapter
Jul 26, 2007 11:32 AM
NikB
Jun 20, 2002 06:46 PM
bronco_jim
Feb 27, 2000 09:12 PM
