302m???
Old Mar 29, 2003 | 10:42 AM
75f100's Avatar
75f100
302m???
ok, i'm new and i guess this has been covered, but i counld not find info in the search. i have seen the cleveland head convesion for the 351W. my question is is it poss. for the <a href="http://www.motorhaven.com/">302 </a>also? and if it is, is it also poss. to substitute modified heads in place of cleveland heads? i was thinking of the M heads because always heard the 302Boss's prob. was to big of ports for the street. thanks
Old Mar 29, 2003 | 12:30 PM
shazam's Avatar
shazam
302m???
Yes you can use the heads And if you can find an old <a href="http://www.motorhaven.com/">302 </a>Boss intake then it will work great with a few mods to the heads for the intake water passages..I think it's the intake that's going to hold you up ....Or you can Look for a set of Boss <a href="http://www.motorhaven.com/">302 </a>heads they have the water passages in them already...
Old Mar 29, 2003 | 01:34 PM
75f100's Avatar
75f100
302m???
i have seen 1 or 2 boss intakes before, on cars. arn't they aluminum? did anyone build aftermarket intakes for these?
Old Mar 29, 2003 | 04:06 PM
ecarter50's Avatar
ecarter50
302m???
Yes there are aftermarket ones available but I can't remember the company. They also made intakes for <a href="http://www.motorhaven.com/">351w </a>with cleveland heads.
Old Mar 29, 2003 | 10:59 PM
GT40man's Avatar
GT40man
302m???
do an internet search for clevor intakes
Old Mar 30, 2003 | 12:20 AM
Brian S's Avatar
Brian S
302m???
Here's a couple sites that should help.
http://www.darkhorseracing.net/clevor_headmod.htm
http://www.pricemotorsport.com/
Old Mar 30, 2003 | 05:59 AM
75f100's Avatar
75f100
302m???
thanks everyone for all the great info, and so fast. it looks like it can be done through price motorsports for roughly $400. thanks again everyone.
Old Mar 30, 2003 | 04:13 PM
NewHolland's Avatar
NewHolland
302m???
The early 70 -71 351c 2v heads (same as M heads visually)due flow a bit better than the late model smog ones on the exhaust side.Remember the exhaust headers will have to be custom..The 351 C 2v ex.manifolds will work..351C 4v will bolt up but wont seal so those are out....food for thought.
Old Mar 30, 2003 | 10:22 PM
GT40man's Avatar
GT40man
302m???
ok iguess my brain is running slow.
if the aussie 302/351c share the same block. like the us 351m/400. how much for a 302c block in the states? hmmmm?
