7.3 IDI Turbo chips/tuners?
Old 07-08-2011, 01:10 PM
LSO1123's Avatar
LSO1123
LSO1123 is offline
Is anyone aware of any chips/tuners available for a 93 or 94 turbo 7.3 IDI?
Old 07-08-2011, 01:24 PM
91dirtydiesel's Avatar
91dirtydiesel
91dirtydiesel is offline
None available. Chip/tuners would require electronics. These engines are all mechanically operated. Now there is other ways of producing more power but, chips arnt an option
Old 07-08-2011, 01:38 PM
LSO1123's Avatar
LSO1123
LSO1123 is offline
That's what I was thinking but I just wanted to make sure. What are some other ways of producing more power? Are they complicated or could a novice like do it?
Thanks,
Chuck
Old 07-08-2011, 03:10 PM
eatont9999's Avatar
eatont9999
eatont9999 is offline
LSO broke the cardinal rule. No computer talk in the IDI forum. HAHA, just kidding.
Old 07-08-2011, 03:12 PM
eatont9999's Avatar
eatont9999
Since you already have a turbo, there aren't many things I can suggest that wouldn't risk damaging the engine or reducing its lifespan. You should make sure your injection pump and injectors are in good order. They last about 100K miles until both start to wear out.
Old 07-08-2011, 03:15 PM
91dirtydiesel
You can also make it breathe better. Open up the exhaust and maybe consider different air intake setup
Old 07-08-2011, 06:54 PM
LSO1123's Avatar
LSO1123
LSO1123 is offline
Well I found a '94 F250 super cab 4x4 with the IDI factory turbo with 230K miles for $3000. It is in great mechanical and cosmetic shape. Already has pillar boost/pyro/trans temp gauges installed has straight pipe exhaust but I'm not sure what brand. I was wanting something that I could add a chip/tuner which would have to be a 94.5 or newer power stroke. I found a '95 F250 supercab 4x4 with 242K miles that has a little rust on the right fender but other than that it's also in good shape for $4000. If you were picking between these two trucks, which would you go with?
Old 07-08-2011, 07:56 PM
GHeTTo JOe's Avatar
GHeTTo JOe
GHeTTo JOe is offline
for sure i'd go with the idi parts are alot cheaper and less likely to fail.
Old 07-08-2011, 08:46 PM
540milotalon's Avatar
540milotalon
540milotalon is offline
I sound like a broken Record/CD, I have both and like both. If you want to be able to service it inexpensively; go IDI. If you want more power, DI. If you go DI, have someone run an A/E (Auto Enginenuity) scan on the truck first.
Old 07-08-2011, 09:49 PM
starmilt's Avatar
starmilt
starmilt is offline
Several of my rancher friends traded their turboed idi pickups for the power strokes when they came out for the extra power, and were upset over their loss. lol
Old 07-09-2011, 09:56 AM
Aune163rd's Avatar
Aune163rd
Aune163rd is offline
I trust an IDI over a powerstroke, you can get the IDI's to keep up with early powerstrokes, but after that the stroke will run circles around the IDI, but the IDI will give you 300k+ miles of service, and its damn near impossible to break it if you take care of it and dont run the engine at the governor. You can blow head gaskets but as long as there is oil in the case, fuel getting to the engine, and a cooling system. You should be just fine.
Old 07-09-2011, 11:18 AM
ADTMan's Avatar
ADTMan
ADTMan is offline
IDI IDI IDI IDI IDI IDI!!!!!!!!!!!!!!!!!!!!!!!!! No no to the powerchoke!
Old 07-09-2011, 12:40 PM
540milotalon
The Powerstroke is an IH, so let's all be friends! Let's all spread the ugly truth about those stinking Bow Tie Izuzu's. Duratrash
Old 07-09-2011, 01:55 PM
LSO1123's Avatar
LSO1123
LSO1123 is offline
Anyone know who makes a turbo back exhaust for the factory turbo IDI? I looked at ATS and it says their system is made to fit their turbo system and would require extra parts to fit the factory turbo system.
Old 07-09-2011, 02:54 PM
540milotalon
I thought the ATS was the "Factory" turbo system?
Quick Reply: 7.3 IDI Turbo chips/tuners?
