Compression tester
Old Jul 8, 2011 | 03:33 AM
ChunderDownUnder's Avatar
ChunderDownUnder
Compression tester
Im looking at a compression test kit. What size fitting do I need for the glow plug.
Most kits I have seen have a M10xM1.25. Is this the right size. ??
Old Jul 8, 2011 | 06:02 AM
hotroddsl's Avatar
hotroddsl
No those will not work the glow plugs are M10x1.0 snap-on makes the best one I've found yet you can screw it in without interference from rockers as as the hose is integral to the tip pricey at 100.00usd I don't know what that relates to in bills with the Queen on them but here it's worth it just to loose the hassle. Good luck!
Old Jul 8, 2011 | 07:49 AM
mueckster's Avatar
mueckster
Is that the price for just the hose? I have found the adaptor w/ integral hose for $23.95, but may have to change the male plug to work with my coupler. The picture of it wasn't detailed enough to tell. I have access to a hydraulic hose press and change out the end to 1/8" NPT and use one of the plugs in my kit.
Old Jul 8, 2011 | 07:54 AM
ChunderDownUnder
is this the one
Snap On Tools Compression Tester | eBay
no mention of M10x1.0
My bad its for a gasser
Old Jul 8, 2011 | 08:05 AM
ChunderDownUnder
is this the adaptor
M3545B, Adaptor, Glow Plug Compression (for 6.9L diesel engines)
44 AUD.
or this
http://cgi.ebay.com.au/ws/eBayISAPI....=STRK:MEWAX:IT
Old Jul 8, 2011 | 09:24 AM
PaysonPSD's Avatar
PaysonPSD
Brian,
Have you got an old glow plug? Cory (Ziggy) made an adapter out of an old glow plug. I followed suit. Was pretty simple. Removed the heating element, then ground the corners off the hex and used a 1/8" NPT female tap to cut the threads. It will screw right into a standard grease gun hose.
Old Jul 8, 2011 | 12:38 PM
hotroddsl's Avatar
hotroddsl
That first one will work paysonpsd's got a good idea its the same thing, the one I'm talking bought is the 7.3 specific adaptor it has the hose integral and is o-ringed at the tip, with a connecter 10" up the hose.
Old Jul 9, 2011 | 07:15 PM
ChunderDownUnder
Nah Robin no spare glow plugs.
What if I get the adaptor and then this tester
DIESEL COMPRESSION TEST KIT 8PC - NEW | eBay
take them to my local hose guy and get him to match em up. Im time poor and really dont mind paying if it works.
Old Jul 10, 2011 | 01:33 AM
hotroddsl's Avatar
hotroddsl
that looks like it has the correct adapter included its the first one on the left the long one!
ScottJM
24
Oct 22, 2018 05:45 PM
TKegs763
36
Jan 22, 2014 03:43 PM
miashley150
Mar 24, 2013 06:59 PM
DANDEE1996
General Diesel Discussion
32
Oct 27, 2005 09:00 PM
Goodold71
Oct 19, 2003 03:39 PM
