Sponsored by: Kumho
"Comfort Shock"
Old Jul 7, 2011 | 08:57 PM
JOHNSHO's Avatar
JOHNSHO
"Comfort Shock"
95 f250 5.8 4x4
Suggestions on the best reasonably price "best riding" shock for my F250.
God Bless
John
Old Jul 7, 2011 | 11:35 PM
Beechkid's Avatar
Beechkid
Shock Recommendations IMHO:
1) Koni- Excellent for racing applications- overpriced for street applications
2) Tokico, QA1 & Bilstein- A very good shock for street/strip applications. If you are running very stiff tires on the street (such as Bridgstone that are 100% steel belted or tires with profiles shorter than 50 series), these provide the extra give that you need for both comfort & stability
3) KYB- A very good shock for street/strip applications. If you are running a softer tires on the street (such as BFG that are a mix of steel & nylon belted or tires with profiles not shorter than 50 series), these provide the extra stiffness that you need for both comfort & stability. The Exel-G’s (formerly GR-2) are the equivalent to the Edelbrock IAS automatic adjusting units. Overall, stiffness between the Gas-a-just and the GR2’s are the same, the difference is the GR-2's valving which stiffens things up from a oem setting to that of the Gas-a-just units.. Best shock for the $/best price typically found at Performance Suspension Technologies (PST) and typically about 1/3 less than Bilstein.
4) Gabriel- A very nice good quality HD OEM replacement type unit.
mattmck
May 20, 2015 02:22 PM
JOHN2001
Feb 21, 2011 05:44 PM
brembo
Oct 14, 2010 11:40 PM
71hightoy
Offroad & 4x4
Nov 19, 2009 11:09 AM
johnw
Apr 10, 2006 06:58 AM
