What would you do
Old Jul 7, 2011 | 08:52 PM
green 69's Avatar
green 69
What would you do
Ok I have to make an decision, a coupl of months ago my 7.3 cracked a piston and has a hole in it. So now is the time to do something about it.
I use the truck for towing my fifthwheel toybox, and boat, and just running around town. I have to spend money one way or the other, If i could get some extra ponies for towing and still have a reliable motor.
I have 200k on the motor turbo shows a little wear, injectors are stock.
Do I rebuild the motor, and have a hotter cam setup, go with a bigger turbo and better injectors, and try to get 400hp with out an tuner.
Or buy a reman 7.3 from clay and add just a new turbo setup and run a chip from dp
Ford wants 9,500 for a complete reman, thats a plug and play
Old Jul 7, 2011 | 09:03 PM
BigAlsPSD's Avatar
BigAlsPSD
It is possible to just replace the one piston, if all else is good maybe look into an overhaul kit, Riffraff Diesel: Ford Overhaul Kit, or complete long block, Riffraff Diesel: Ford Enhanced Long Block , then add say a Stage 1 Kit or Stage 2 Kit kit, which will keep you well under that price of 9500. I contemplated it as well, got lucky and found a good 7.3 on craigslist for $750 dropped it in with some fullforce injectors been going strong for about 8,000 miles so far, but I am working on my motor originally in the truck as a rebuild now. I looked at my relatively cheap "gamble" which has paid off so far, to buy me time to rebuild.
Old Jul 7, 2011 | 09:09 PM
snakedoc's Avatar
snakedoc
i think if you have the time i would rebuild. or find a used motor
Old Jul 8, 2011 | 03:19 AM
slim613's Avatar
slim613
i go with a rebuild, most likley worth it in the long run because u know wen and wat ur motor has and been thru and when
Old Jul 8, 2011 | 03:25 AM
slim613's Avatar
slim613
oh and actualy i have a 2002 with a 2001 motor that im clueles about everthing on idk how many miles are on it and u know how many are on yours and you will know wats inside unlike me so id keep the motor u got runnin unless its real bad
Old Jul 8, 2011 | 06:36 AM
hotroddsl's Avatar
hotroddsl
Rebuild! If you plan on doing any serious HP mods you will need to know exactly what you have as a foundation to work from, ie...bal blueprinting, crank treatment, NEW COOLING JETS!, camshaft. Not to mention heads it's just so much easier to put your faith into a local machine shop with a reputation to up hold that will give your engine the attention it deserves then to trust some unnamed guy who is just on the line to get a check and does not care if that rebuild goes bad, because chances are those rods are good enough for most and that head is flat enough for most ect...
Old Jul 8, 2011 | 12:15 PM
73ferdf250highboy's Avatar
73ferdf250highboy
slap a piston in there and be done with it
91 Super Duty
50
Oct 14, 2021 11:43 AM
big ole ford
Nov 18, 2013 07:02 PM
HKusp
69
Nov 18, 2013 07:12 AM
akamacgyver
Oct 9, 2011 09:02 AM
Krupka
16
Jun 15, 2010 11:29 PM
