'87 fuel vent line
Old Jul 7, 2011 | 04:47 AM
sg1099's Avatar
sg1099
Smile '87 fuel vent line
i have a '87 project woods truck.straight 6, 4 sd granny,35"tires,camo .i got the fuel issues about wrapped up,but the vent hose that is connected to the fuel tank, goes to the engine bay.i don't know where it goes.it travels along the right frame and sticks up just rear and below the battery.i was told it connect to a canister of sorts but what?there are two round and one rectangle.what are these canisters,what do they do,where do they go?got to do my honey do list,check back later, thanks.
Old Jul 7, 2011 | 10:31 AM
HD's Avatar
HD
sg1099,
My truck has a 5.0 and is a 91, but you may have the same type of evap canister I do. My truck has coffee can looking ones which are vacuum canisters. There is a rectangle one that is the evaporative emissions canister. The fuel tank vent line runs up to it. The canister is filled with charcoal which absorbs the fuel vapors when the truck is off. When the engine is running, fresh air is let into the top of the canister while vacuum is applied through a separate hose to the canister, drawing the vapors into the intake. Here are a couple of pictures of mine. These pictures are from the AllDataDiy website. Hope this helps!
Chris
Old Jul 7, 2011 | 01:59 PM
sg1099's Avatar
sg1099
thanks.the rectangle canister was the one that didn't have anything hooked to it.thanks again.
Old Jul 7, 2011 | 05:29 PM
5Rangers's Avatar
5Rangers
Sure would like to see a picture of the camo F150, thinking about doing it to mine. Did you get it in camo or do it yourself? If you did it yourself, how did you do it?
Old Jul 17, 2011 | 02:44 PM
sg1099's Avatar
sg1099
sorry it took so long to get back but, when the job calls i got to listen. yes i did the camo job my self. first i sanded the truck with a scotch-brite pad,than hosed it down. when dry,i used 6-7 cans olive drab paint.i had done some trimming of some bushes and used them as the pattern. spray flat black and brown,with touches of gray primer i had laying around.just lightly spray around the edges.one section at a time,ie...hood,fender,door side of bed, tailgateand so on. if you mess up hit it with olive drab again,start over.i dont know how to move pics from my garage to here.if i did i could do so. sorry. thanks for the help.
Old Jul 17, 2011 | 03:07 PM
White 97 xlt's Avatar
White 97 xlt
Here you go.................sg1099' s truck..
Old Jul 17, 2011 | 04:49 PM
5Rangers's Avatar
5Rangers
Thankyou White and SG!!
That looks awesome, exactly what I would like to do with mine. Im thinking of using brown for the base coat though. What kind of paint did you use? Rustoleum has a camo line out with about 4 different colors. I read in some other places that if you want it to hold up to go back over it with a few coats of clear, maybe that doesn't matter though..
Anyway,, it really looks great....
Old Jul 17, 2011 | 05:52 PM
sg1099's Avatar
sg1099
i used mostly primer colors but, the base was krylon olive drab.i think the primers were also krylon.glad you like the pics.i didnt clear coat it because i wanted to be able to touch up if needed in the dull finish.which i have done.the under brush in florida is thick,and to get back to my honey hole gets bad.just have fun with the paint.mask off stuff you dont want painted.for a woods truck its great,have fun with it.
alchemist1
17
Mar 18, 2020 07:24 AM
silar
Oct 8, 2016 07:51 PM
Skauber
25
Oct 5, 2016 06:24 AM
sweetfarm
Modular V10 (6.8l)
17
Feb 27, 2016 08:38 PM
axman_F250
Oct 1, 2009 04:43 PM
