Want to put electric fan on 77 f150
Hey all, I want to put an electric fan on my truck to replace the stock straight blade clutchless fan I have right now. The only trouble is, it seems like everyone is saying that I have to upgrade my alternator for all the common swaps. I used to have a flex-a-lite black magic fan on my old 76 f150 with stock alternator and it was just fine. It was a single 17 inch fan that I believe moved about 3,000 cfm. Are there any fans like this on other vehicles that I could get fairly cheap?
ive read theads here of guys doin the 3G swap for as cheap as $25. You would have to hit up your local junk yards. Search for the thread titled "just did a 3g upgrade" there is some great info and a diagram of how to wire up the alt. You will need the taurus alt. Harness and a maxi fuse. 180 amp i think and u can just swap the pulley for your v-belt
https://www.ford-trucks.com/forums/9...hlight=upgrade
here is the link. this should answer any questions you might have.
Dakonthemountain, I am not having any cooling problems at all, I just don't think the straight blade non-clutch fan that I have is the most efficient thing in the world. I want to go electric for efficiency. Thanks 77ford, I will check into this upgrade. Sounds like it wouldn't be too expensive. A new flex-a-lite fan is definitely out of my pricerange though. I am 24, a new dad, sole breadwinner, and making a mortgage payment on $2K a month. So needless to say money doesn't grow on trees around here!! Lol!
These are both great upgrades. I have done the 3g and put a fan from a Mercury Sable (same as the Taurus).
smitty14
2004 - 2008 F150
06-16-2017 10:17 AM
misterbond
03-11-2017 09:40 AM
RadioControlGuy85
10-07-2016 10:17 AM
