Tuneup advice...
Old Mar 28, 2003 | 11:46 PM
Deadblow's Avatar
Deadblow
Talking Tuneup advice...
I have a 97 F250 with the 7.5 and 5-speed. I would like to do some basic tune up work myself but really don't have any under-the-hood experience past changing the oil & air filter. I'm getting about 13 mpg so I don't have any complaints there. I have seen posts referring to various O2 sensors and cats. Where are these and other things I should check on? Also, what do I need to do(gapping, etc) to change the plugs? Are the stock plug wires ok or should I upgrade them also? Thanks as usual for the help.
Old Mar 29, 2003 | 12:53 AM
merc460's Avatar
merc460
Tuneup advice...
If its running good just stick with the basic's plugs, cap, rotor, pcv valve maybe plug wires if the mileage or wire condition indicates changing them. O2 sensor are not part of normal regular maintance unless the miles are high or there is a problem pointing in that direction . Just gap the plugs to spec, check the timing and also change the fuel filter if it needs it. Eric
Ridenred333
2004 - 2008 F150
Jan 19, 2014 11:31 AM
Bigjht
2004 - 2008 F150
Feb 12, 2013 08:34 PM
NMRider
Jul 1, 2012 06:52 PM
equium
General Automotive Discussion
125
Jul 22, 2006 10:41 PM
adbradley
May 21, 2002 08:40 AM
