Stud Extractor suggestions?
Old Jul 15, 2011 | 10:56 PM
wdfp's Avatar
wdfp
Once you get the nut welded on, let it cool a bit, tighten it first, then loosen.. Just go back and forth, it takes a while but usually works very well..
If it does brerak again you are not out anything, just a half inch you dont have to drill...
Old Jul 15, 2011 | 11:01 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Post # 3 vice grip trick, Harbor Freight ah....no comment, try Fastenall for the good stuff.
Drilling thru weld goobers is no fun and keeps you from getting a good center punch mark.
Old Jul 15, 2011 | 11:06 PM
73 ford guy's Avatar
73 ford guy
There's so many ways to do it. Drill it, extract it, vise grip(good sharp grip curved jaw ones) or welding. I wanna know what the welder is cause you need a good hot one put in there first try not a 110 buzzbox with the setting too cold or too much wire speed and it stubs back and doesn't penetrate.
Old Jul 16, 2011 | 01:07 PM
FordmanShane's Avatar
FordmanShane
No luck fellas, 73FG.. the welder was a 110 harbor freight buzzbox I couldn't get any penetration. Drilling was the last thing i wanted to do, but it looks like I might have to. I know any ez out tool wont work, this bolt is seized!
Old Jul 16, 2011 | 01:14 PM
Tsoptich's Avatar
Tsoptich
Maybe you can drill it out and then use a tap and die to set threads for a new bolt
Old Jul 16, 2011 | 01:32 PM
73 ford guy
Well I pretty much new the welder trick wasn't going to work as those 110 welders are pretty useless. You needed a 230v mig again for a good hot weld. You know my bracket for my Saginaw pump has a long threaded rod out of block in that same spot and the 7/16 would flex too much after tightening causing a bad alignment on belt. I drilled out the hole to just make it smooth taking out 7/16 threads and tapped it. The 1/2" rod now doesn't flex and belt aligns better.
So drilling isn't the worst thing but going to a larger 1/2" should eliminate this problem down the road as it would be much tougher to break.
Old Jul 27, 2011 | 11:25 PM
FordmanShane
update
Alright I'm almost done, I have a few concerns I'd like to point out...the tap I used only made 3 or 4 good threads. I don't think that's going to work out..do I now need to get a tap with a barbed tip? or no? Also the plate is warped...im wondering if i should go down to picknpull and get one tomorrow..
Old Jul 27, 2011 | 11:42 PM
73 ford guy
What size tap? 7/16?
I'd go with a 1/2 course tap. Don't use fine thread
Old Jul 27, 2011 | 11:48 PM
FordmanShane
I went with the 1/2 course tap
Old Jul 28, 2011 | 03:57 AM
Cummins_Power_89's Avatar
Cummins_Power_89
Best thing I've found for broken bolts/studs is an air hammer. A lot of times (if the part can withstand the force) a good air hammer with a flat bit (shaped like the head of a hammer) will hit it hard enough to break the bond of the rust. That and some good penetrating oil will get it finger loose. I prefer and reccomend kroil. Works like a charm and a good air hammer with some good power and you got it no problem. Good luck
Old Jul 28, 2011 | 08:56 AM
73 ford guy
Originally Posted by FordmanShane
so do you think about the thread issue?
Hey thought about it and I think I know your problem. Engine blocks are a different type of steel so I think you either 1: took too much material out in one go and you needed the original hole a tad bigger or 2: you didn't use a good tap oil or combination of both!
You might have to go up to 9/16 budz , but be sure to start with a good hole probably just knocking out old threads and do it again. Slow and steady. 1/2 a turn in 2 turns out. I had a bad tap hole like this once and it was most likely I took too much material out in one go and chips jammed taking out fresh threads and no oil.
Good luck
Old Jul 28, 2011 | 12:33 PM
FordmanShane
How far can i drill into the block? I think im about 9/16'ths into the block...i don't want to hit anything....
Old Jul 28, 2011 | 12:52 PM
  #28
gfw1985's Avatar
gfw1985
Cranky Old Guy
I haven't read the whole thread. If using a regular tap it's tapered and you might get a few more threads using a bottom tap.
Old Jul 28, 2011 | 02:12 PM
  #29
73 ford guy
That hole should be 3/4" deep at least.
Old Jul 28, 2011 | 02:45 PM
  #30
FordmanShane
That's what i should have used thanks
