Carbs need air.
Old Jul 6, 2011 | 11:39 AM
shotgun2's Avatar
shotgun2
Carbs need air.
I have a 1978 F100, with a 1 bbl carter YFA.
4 years ago i sent the carb to be rebuilt, it sat in the driveway for 4 years, other then the occasional start. ( 2 or 3 time a years )
I am finally back at it, it started fine, i check,
it idle nicely, but as soon as i try to push on the gas pedal, you can hear the carb trying to suck air..... like it's running out of air.
1) I moved the need for the fuel mixture, all the way in, and turn it back 2 full turn.
2) i checked with a light the timing, but i forgot to plug the advance vaccum, ( will redo tonight)
3) (i think i have all the vaccum plug right) i remove the manifold tube and plug all 6 hole, and remove the AIR pump.
4) i replace the gas, put gas treatment in the tank
5) tried a carb cleaner from the top,
thought?? suggestion ??
Sincerely
Gerald.
Old Jul 6, 2011 | 01:52 PM
ctubutis's Avatar
ctubutis
With the engine off, remove the air cleaner and look down the throat of the carb as you fully open the throttle with your hand, you should see two strong streams of gasoline being injected.
If there are none (or only a dribble) that points to the accelerator pump on the carburetor as a likely place to begin looking.
Old Jul 6, 2011 | 01:55 PM
shotgun2's Avatar
shotgun2
well, i will try tonight
if not i am thinking of taking it out, we have an ultrasonic washing machine here, and dumping the entire carb in it
G
Old Jul 6, 2011 | 06:06 PM
billt28's Avatar
billt28
Sounds to me like the carb needs rebuilt from sitting. The gas inside the carb has caused varnish to build up, and needs removed.
rustoleum82
Feb 11, 2015 01:14 PM
Floggit
Dec 22, 2013 04:52 PM
hornetman
May 19, 2009 02:35 AM
kenworth20
Nov 24, 2006 02:52 AM
Gerald Ash
Mar 1, 2000 05:06 PM
