Black injector tip
Old Jul 5, 2011 | 07:43 AM
Krazymaan's Avatar
Krazymaan
Black injector tip
So i pulled the old AD injectors out of my 7.3 and noticed this.
One injector had burnt on textured black oil deposits totally covering the bottom 1" (shinny part) of the injector. Even the orange O ring at the bottom was black, couldn't tell it was ever orange and the brass washer at the tip was black. Black, like an old cast Iron skillet that hasn't been washed in 5 years. Actually had to use a green scrubbie and gasoline to get that black burnt on sootie oily deposit off.
I am assuming thats from a bad injector cup or an injector hold down bolt that became loose? Although the bolt was tight.
Old Jul 5, 2011 | 08:07 AM
hotroddsl's Avatar
hotroddsl
Replace the washer at a minnimmum, mine would get new cups, washers, injectors serviced, and a compression test, but that's a personal choice! Hoh many miles? Witch injector? What led you to pull injectors? ect....?
Old Jul 5, 2011 | 08:22 AM
Krazymaan's Avatar
Krazymaan
I pulled the motor to put a new motor in. pulled the injectors to look at them. Just stating my discovery. But it was #4 cylinder.
Old Jul 5, 2011 | 08:25 AM
hotroddsl's Avatar
hotroddsl
Gotcha that's classic combustion leak almost always from loose injector and it's a cup killer!
Old Jul 5, 2011 | 11:01 AM
stugots's Avatar
stugots
Hmm, I pulled all my injectors this weekend and they were all black.
Old Jul 5, 2011 | 11:43 AM
PaysonPSD's Avatar
PaysonPSD
This is why we always say to check the injector hold down bolts for the proper 120 in/lbs of torque.
Good routine whenever you pull the VCs is to check the injector holdown bolts, rocker pedestal bolt torque (20 ft/lbs) and ensure that the UVCHs are tight and that no wires are chaffing.
3000gtman
Feb 2, 2017 08:27 AM
Aune163rd
1983 - 2012 Ranger & B-Series
Oct 20, 2016 01:07 PM
bl1989
Jul 7, 2016 03:02 AM
Brian Ski 44
Jun 26, 2016 06:45 PM
Damonkr
Mar 25, 2010 09:04 AM
