2011 F150 Supercrew Ecoboost - Fuel Economy on Highway - Mine 17.4 at 74mph
Old 12-14-2011, 08:54 AM
thomastl's Avatar
thomastl
thomastl is offline
All I can tell you is that sway control defaults to on all the time. You have to turn it off every time you crank up. I actually felt the brakes release when I turned it off on the interstate. Mileage immediately went up.
I assume there are some kind of rate sensors in the rear of the truck that detect sway.
I know based on my experience that it was activated and I had no trailer connected. I would assume it is there for when you have a heavy load in the bed as well to help prevent rear sway.
As for the 02 Sensor, mine was fine. Not my problem w/ poor economy but could be on others.
  #62
Old 12-14-2011, 03:27 PM
schrod's Avatar
schrod
schrod is offline
Originally Posted by truckerdude
Trailer sway control and traction control are different. Traction control is activated or deactivated by a button on the dash. Sway control is activated/deactivated in the 4.2" display menu. Sway control does depends up the circuitry in traction control to function, however deactivating sway control thru the menu does NOT turn of the traction control.
Thank you truckerdude for supplied info. It reiterates what I was trying to get across. Thomastl---I really could not tell any difference when I deactivated mine. On your pickup maybe there is something wrong and it did make a big difference. I could not tell any difference.
  #63
Old 12-15-2011, 02:39 AM
67gt351's Avatar
67gt351
67gt351 is offline
Yes, thanks for that comeback. My 02 sensor is also find. It was the computer, they reset
it, I am back getting 22 on highway @ 65mph. Happy camper again!
  #64
Old 12-15-2011, 03:26 AM
caere's Avatar
caere
caere is offline
Can you find out what version you had reloaded on the ECU or PCM?
  #65
Old 12-15-2011, 03:59 PM
67gt351's Avatar
67gt351
67gt351 is offline
Fuel Economy
Basicly they are stating reprogram the Powertrain Control Module (PCM)
using IDS release 75.03 and higher, whatever that means. Using the IDS tool, clear the transmission adaptive table, and perform adaptive drive cycle. Condition Code 04. Hope that helps! What happened to the good
old days when you worked on your truck in the back yard, with a timing
light and dwell meter.
  #66
Old 12-15-2011, 04:08 PM
stagalv's Avatar
stagalv
stagalv is offline
Those days are gone ! No more shade tree mechanics.
Cylesdale
6.2L V8
08-19-2017 12:19 AM
kermmydog
05-08-2017 04:27 PM
Gary Lewis
2015 - 2020 F150
36
09-07-2016 09:21 PM
Jupiter3102
6.2L V8
03-30-2015 05:31 PM
cruzerjd
Modular V10 (6.8l)
03-11-2012 03:06 PM
Quick Reply: 2011 F150 Supercrew Ecoboost - Fuel Economy on Highway - Mine 17.4 at 74mph
