2011 F150 Supercrew Ecoboost - Fuel Economy on Highway - Mine 17.4 at 74mph
#61
All I can tell you is that sway control defaults to on all the time. You have to turn it off every time you crank up. I actually felt the brakes release when I turned it off on the interstate. Mileage immediately went up.
I assume there are some kind of rate sensors in the rear of the truck that detect sway.
I know based on my experience that it was activated and I had no trailer connected. I would assume it is there for when you have a heavy load in the bed as well to help prevent rear sway.
As for the 02 Sensor, mine was fine. Not my problem w/ poor economy but could be on others.
#62
Trailer sway control and traction control are different. Traction control is activated or deactivated by a button on the dash. Sway control is activated/deactivated in the 4.2" display menu. Sway control does depends up the circuitry in traction control to function, however deactivating sway control thru the menu does NOT turn of the traction control.
#64
#65
Fuel Economy
Basicly they are stating reprogram the Powertrain Control Module (PCM)
using IDS release 75.03 and higher, whatever that means. Using the IDS tool, clear the transmission adaptive table, and perform adaptive drive cycle. Condition Code 04. Hope that helps! What happened to the good
old days when you worked on your truck in the back yard, with a timing
light and dwell meter.
kermmydog
05-08-2017 04:27 PM
