AE Help...
Old Jul 3, 2011 | 09:02 AM
F-250 Super Duty's Avatar
F-250 Super Duty
AE Help...
Trying to use AE for the first time and I keep getting this message. Any ideas?
Old Jul 3, 2011 | 09:19 AM
23larry24's Avatar
23larry24
Mine did something similar when I bought it, I believe I had to update the pro-link connector. If you look under the help tab there is a couple of link to get the latest updates.
Old Jul 3, 2011 | 11:50 AM
F-250 Super Duty
Tried the update, but mine was up to date, I think there might be something else wrong too. I got the following message and it should have had a number listed in section b.
Old Jul 3, 2011 | 01:43 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Did you activate your enhanced version?
Check to see if the connector ID is the same as on the box lid.
Old Jul 3, 2011 | 02:06 PM
ToMang07's Avatar
ToMang07
+1 did you activate the "Ford" bundle? Should be on a separate card with the number on it.
Old Jul 3, 2011 | 02:27 PM
woodnthings's Avatar
woodnthings
Make sure you activate the product, and also make sure the key is in the RUN position.
Old Jul 3, 2011 | 03:12 PM
zx250's Avatar
zx250
Of the next Riffraff East
Yeah, don't look like it's been registered. I've seen that before, after every upgrade.
F-250 Super Duty
Yup, the enhanced bundle activation number was on a blue sheet of paper. But when I did I had the same message that was in the second picture saying it was not connected. I followed the directions on the paper and it didn't say to have the connector plugged in. On the blue sheet it even said ignore the not connected messages.
The only thing that the connector has on it is a sticker that says 55845-P the top of the box has a sticker that says Ford Enhanced Bundle with 55845 written on it. The box lid doesn't have the "-P" like the sticker on the connector???
I uninstalled AE and when I reinstalled it the same thing happened. When I reinstalled it the enhanced package was already unlocked so it must have left some files on the computer some where.
Not sure what to do.
Old Jul 3, 2011 | 03:15 PM
ToMang07's Avatar
ToMang07
Well that sux.... sounds like it's time to contact AE. Of course it's a holiday weekend.
Old Jul 3, 2011 | 05:21 PM
bobbyrjw's Avatar
bobbyrjw
https://sites.google.com/site/woodnt.../autoenginuity
This site covers the correct settings. He usually answers posts on here about AE.
Wood-N-Things has some great AE info.
Old Jul 3, 2011 | 05:23 PM
bobbyrjw's Avatar
bobbyrjw
Hey Clay, any way to get some of the AE folks to come to RRE? Or maybe you can give us a class on it?
I know that I am not using it to its fullest. Once AE couldn't find anything wrong with my truck, it doesn't seem to be useful.
Old Jul 3, 2011 | 06:38 PM
F-250 Super Duty
Nice site Ken! Lots of good info there if I could only get the computer to regonize the adapter is the right one....
This is activated right?
Old Jul 4, 2011 | 06:17 AM
bobbyrjw's Avatar
bobbyrjw
Check the communications options
I had to pick these options to make mine work.
Old Jul 4, 2011 | 08:18 AM
CGMKCM's Avatar
CGMKCM
Do you have power at the OBDII port? Blown fuse for the cig lighter/power port is my guess.
Try connecting to any other late model car you have available. As long as it has OBDII it should connect.
I had the same problem you are having and went and complained to AE and even shipped the cable back to them. They found nothing wrong and shipped it back. I tried it again and it didn't work. I then called AE and they told me to try another car. It worked fine. I then replaced the blown fuse in my truck and it worked great.
It was a humbling experience.
Old Jul 4, 2011 | 09:40 AM
ToMang07's Avatar
ToMang07
Good call, that could very well be his problem. Same fuse as the cigarette lighter, I believe.... is the lighter working?
