ANOTHER PROBLEM
Old Jul 4, 2011 | 12:47 PM
brokeisnojoke's Avatar
brokeisnojoke
ANOTHER PROBLEM
Ok so I was driving yesterday and my engine light came on and started running like crap. Checked codes and it said injector pressure lower/higher than desired. Can't remember code # it would also shut off every time I stopped. Pulled filter and it was black.
Old Jul 4, 2011 | 01:10 PM
IDMooseMan's Avatar
IDMooseMan
Sounds like it's time for a new fuel filter. Might as well clean the Fuel Pressure Regulator (FPR) screen while you're at it and test the fuel pressure at the schrader valve. Should be 40 - 80 PSI at idle.
Do a search for "FPR Shim" to get yourself started. Ask questions. We're here to help.
Welcome to the site.
Old Jul 4, 2011 | 01:12 PM
brokeisnojoke
Also there is some who're looking thing in the fuel bowl that I didn't notice last time I changed the filter
Old Jul 4, 2011 | 01:25 PM
IDMooseMan's Avatar
IDMooseMan
Huh? Are you talking about something at the bottom of the fuel bowl? Or something came loose and has settled to the bottom?
There is a fuel heater at the bottom.
Old Jul 4, 2011 | 01:28 PM
brokeisnojoke
Its a little wire its attached but I never saw it before
Old Jul 4, 2011 | 01:32 PM
IDMooseMan's Avatar
IDMooseMan
The only wires I can think of would be for the fuel heater or the "Water in Fuel" sensor.
One of the gurus around here will correct me if I'm wrong.
Had another thought, too, about your filter being black. Are you having an algae problem with this rig? Are you getting fuel from a reputable source?
Old Jul 4, 2011 | 01:35 PM
brokeisnojoke
Get fuel from the same place every time and never had a problem. I changed filter once and it wasn't black
Old Jul 4, 2011 | 01:44 PM
IDMooseMan's Avatar
IDMooseMan
Does this place have a high turn-over rate for their diesel pumps? If they got a bad shipment and the fuel sat in the tanks for awhile, they may have the algae problem and passed it on to you when you filled up.
Any chance you take a picture and post it to this thread?
Old Jul 4, 2011 | 01:45 PM
bad12jr's Avatar
bad12jr
I would defiantly clean the bowl and possibly rebuild it. Never gonna hurt to do some pm
Old Jul 4, 2011 | 01:46 PM
brokeisnojoke
I could try ya
Old Jul 4, 2011 | 01:47 PM
brokeisnojoke
Will do. And idk how to post pics from my phone
Old Jul 4, 2011 | 02:10 PM
IDMooseMan's Avatar
IDMooseMan
You'll need to upload the photo to your "Garage" or "Gallery" on the FTE site or to another photo storage account like "Photobucket" or something similar.
Once it's there and available, you can view the photo, select (copy) the image [IMG] code and paste that code into the thread.
If you don't have enough posts to have permission to do that, you can send the photo to me and I'll try to post it in the thread for you.
Email: IDMooseManatIdahoTurboDieselsdotcom if you want me to try. Let me know if you do, I'm not viewing my email at the moment.
Old Jul 4, 2011 | 03:33 PM
brokeisnojoke
Im gonna send them to your email. I can't figure it out
Old Jul 4, 2011 | 03:34 PM
Talyn's Avatar
Talyn
MOOSE! where did you come from?
I got an FPR shim article for my website almost finished, I'll post it soon.
Old Jul 4, 2011 | 03:50 PM
brokeisnojoke
Pm your email bc it said it was invalid
