Need help taking pan off
Old Oct 24, 2002 | 07:47 PM
oregon250's Avatar
oregon250
Old Nov 16, 2002 | 05:26 PM
etrade's Avatar
etrade
[updated:LAST EDITED ON 16-Nov-02 AT 06:55 PM (EST)]Engine is jacked up two inches and pan won't come off.
What am I doing wrong? Eveything is cleared below the pan.
It's hitting something inside about one inch back.
This is a 460, 89 F250, 4x4.
Old Nov 16, 2002 | 05:30 PM
PATS2002's Avatar
PATS2002
The oil pump p/u most likely can u go higher ?? careful
Old Nov 16, 2002 | 05:33 PM
etrade's Avatar
etrade
[updated:LAST EDITED ON 16-Nov-02 AT 06:41 PM (EST)]No. It won't go any higher. Do I have to line up the crank some how?
Old Nov 16, 2002 | 06:00 PM
PATS2002's Avatar
PATS2002
[updated:LAST EDITED ON 16-Nov-02 AT 07:02 PM (EST)]No the pick up is bolted to the bottom of the oil pump. Did you un-hook the exaust according to the book u need 4 inches.
Old Nov 16, 2002 | 06:25 PM
etrade's Avatar
etrade
I disconnected the cross over exhaust on one side acording to the book.
I manage to get two bolts off the pick up but I cant remove it.
Old Nov 16, 2002 | 06:38 PM
PATS2002's Avatar
PATS2002
can u unbolt the pump ??
Old Nov 19, 2002 | 09:46 AM
blu's Avatar
blu
Sounds like you are hitting the oil pickup. Theres two hex head screws holding the pickup to the oil pump and a bracket holding the tail of the pickup to one of the bearing blocks(#3?). Remove the two screws plus the bolt holding the bracket in place and you should have enough play in the pu to wiggle it free of the pump.
Old Nov 19, 2002 | 06:59 PM
Steve91's Avatar
Steve91
What is preventing you from lifting the engine higher?
Old Dec 6, 2002 | 10:41 PM
Maniac's Avatar
Maniac
Post Need help taking pan off
It is definitely the oil pick up. I had to unbolt it by feel before the pan would come off and then put it on by feel when I reinstalled. There was no way to get the engine high enough.
