Increasing Horse Power Question
Old Jul 3, 2011 | 03:38 PM
Trojan8975's Avatar
Trojan8975
I have a stock 1992 Ford F150 Nite thats needs some mild upgrades to increase its torque, mpg, and/or horsepower. What upgrades do you recommend? It is a 4x4 with 5.0 302 and a 5-speed.
Old Jul 3, 2011 | 04:12 PM
Conanski's Avatar
Conanski
That motor needs a cam badly and no other change will have as much effect on engine power. It's not that expensive to do a cam swap but it is quite a bit of work, figure on about $300 for the cam and another $50 or so for a gasket set and a whole day to do it.
Depending what cam you pick and how your truck is currently setup a gearing change is the next best upgrade, you want 4.10's for tires up to about 31" and 4.56 or higher the bigger you go from there.
Old Jul 3, 2011 | 11:08 PM
ostrx250's Avatar
ostrx250
if you do a cam you need to grind the exhaust ports out two match the gasket at the very least the best bang for the buck is a new set of heads the cheapest jump is a new cam but is also necessary. tell us what you do and your results
Old Jul 3, 2011 | 11:26 PM
chris11376's Avatar
chris11376
take your heads to a good machine shop and have them built most decent head shops can tell you what would be the best for youe engine, and its usually cheaper to get your old heads built than to buy a new set of built heads. If there is a Dover cylinder head near you they do great work
Old Jul 4, 2011 | 12:20 PM
Conanski's Avatar
Conanski
I have to disagree with these two statements. I have put cams in several of these truck motors and without any other changes the gains are substantial. That's not to say that changing or modifying the heads won't produce gains too, it will... but it's not "required".
And with a flat tappet motor a cam change is easily the best bang for the buck, you can have a cam and lifter set and the necessary gaskets to change it for $200-$250, while rebuilt heads are gonna cost $500 alone.
Old Jul 4, 2011 | 12:25 PM
bladez51's Avatar
bladez51
I agree with ostrx250 based on my observations.
I'm no expert on the 5.0 for trucks, but my friend had a '93 Mustang GT and the single improvement that gave him the greatest gains was porting and polishing the heads... Now, I'm sure that the cam in the truck engines is made for longevity and greatest torque at certain rpm. I imagine that changing the cam would make a noticeable difference and probably works great in conjunction with good heads.
Everything else he did (which was a lot, including the cam) did very little difference in power. All this was checked on the dyno.
Old Jul 4, 2011 | 12:34 PM
Conanski's Avatar
Conanski
Originally Posted by bladez51
Now, I'm sure that the cam in the truck engines is made for greatest torque at certain rpm.
Yeah that's key, the truck cams are designed that way and as a result are very restrictive compared to even the stock HO cam.. and particularly with the early EFI motors. In fact the HO cam is a great way to unleash quite a bit of HP on the cheap with these truck motors.
Old Jul 4, 2011 | 04:32 PM
rla2005's Avatar
rla2005
I am siding with Paul on this one. A better cam is a very good first step on these truck engines. Porting of any type is "not required" to benefit from the upgraded cam.
Old Jul 4, 2011 | 05:08 PM
Terpfords's Avatar
Terpfords
Depending on your budget and timeline, this is the beginning of a long journey. If your not in a hurry there are always good deals to be had.
I went to Carlisle and picked up an Explorer intake for $50. H.O. cams can be had nothing. A switch to Mass air?
But depending on your mechanical skills, you can do them all yourself in progression. The big 4 are exhaust, intake, heads and cam. Most people develop their mechanical ability and confidence by progressing in that order of improvements.
Have fun.
Old Jul 4, 2011 | 06:22 PM
lew52's Avatar
lew52
The 92 5.0 has a small cam , so yeah a cam will help a bunch , the mustangs use the same heads as the truck but use the HO cam , so they make more HP , the 5.0 intake is fine , long tube headers will help and are a must if you upgrade the heads , and should be one of the first upgrades , exhaust , cam , heads and gearing will all help.....Lew
Old Jul 5, 2011 | 03:57 PM
deljac's Avatar
deljac
conansky. you sound like you have done these cam swaps. i have a 95 4x4 with the 302 what cam have you found is the best hp increase
Old Jul 5, 2011 | 04:58 PM
Conanski's Avatar
Conanski
If your truck is MAF the Ford E303 is hard to beat in terms of peak HP but.. it'll be a complete dog below 3000rpm so you will also need steep gears(4.10-4.56) in the rear axle.
Old Jul 5, 2011 | 10:06 PM
deljac's Avatar
deljac
what is MAF and i run 32" tires and am planning on 4.56 gears
Old Jul 6, 2011 | 04:05 AM
SideWinder4.9l's Avatar
SideWinder4.9l
MAF=Mass Air Flow
SD=Speed Density
Old Jul 6, 2011 | 11:31 AM
bladez51's Avatar
bladez51
quick question
My truck is a '94 XLT with the 5.0 engine. How can I tell if I have the MAF or SD set ups?
