Rear Diff Spline numbers
Old Jul 1, 2011 | 05:29 PM
nwo's Avatar
nwo
Is there a way to tell how many splines a diff has by not taking it apart. I looked all over for a tag or numbers. Am I looking in the wrong spots?
Old Jul 1, 2011 | 07:29 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What year vehicle, what series?
Old Jul 2, 2011 | 07:56 AM
nwo's Avatar
nwo
it is a 76 f150
Old Jul 2, 2011 | 01:50 PM
NumberDummy
Could have 28 or 31 splines. The only way to find out is from the ID tag on the rear axle, usually mounted at 5 o'clock under one of the bolts that retains the carrier (pumpkin) to the housing.
If the ID tag is missing, you'll have to pull an axle. The AXLE code on the Warranty Plate does not define the number of splines once it's decoded.
The AXLE code lists the type of rear axle, ratio, with/without Limited Slip, and the rear axle capacity in lbs.
Old Jul 2, 2011 | 03:09 PM
nwo's Avatar
nwo
Thanks for your help.
ibleedblueoval
1997 - 2003 F150
Jan 6, 2013 05:12 PM
1991 ford f-250
Dec 10, 2007 12:58 PM
brider
Apr 8, 2006 03:27 PM
stegmst
Apr 15, 2005 02:21 PM
