Color-Coded Vacuum Hoses
that I didn't really evaluate what kinds of tubing actually came in colored stripes. That McMaster-Carr site is pretty impressive with lots of choices, technical information, and a reductive product searching engine that really lets you narrow down your choices. They alse sell tubing by the foot, for reasonable prices I thought. I wandered around in that interesting website for an hour. Temperature, UV, ozone, chemical resistance, bend radius, it can all be known for the various tubing products on that website. Even "military grade" with FED standards #'s etc. Interestingly, "Gum Rubber" meets military vacuum tubing standards.
If you select "vacuum tubing" your choices really narrow down, with no colored stripes. But what McMaster-Carr considers to be "vacuum tubing" means industrial grade vacuum tubing, they give vacuum and pressure ratings, etc. I wonder what the vacuum ratings are for the chinese tubing available at my local Auto-Mart. I don't know if that tubing pictured above would really work for vacuum, it might collapse, although you can choose different wall thicknesses.
I think someone who really knew a lot about tubing and polymer characteristics could probably find good stuff there that would closely approximate the OEM stuff our trucks came with originally. For me it was a bit much, information overload. But I was impressed with the ratings for Silicone tubing given on the website, it is really heat resistant (+500 F), flexible (works with barbed fittings, good for automotive applications), and comes in some colors and a variety of I.D.'s and wall thicknesses. It's weakness seems to be it doesn't react well with gasoline or oil.
The 20 or so "Hg that our trucks develop really isn't that high compared to lab or industrial equipment that is close to absolute vacuum at 29.92".
I don't know what the softening effect of underhood temperatures would be on that hose.
Another online favorite of mine is SmallParts.com: The Hardware Store for Researchers and Developers
Low pressure EPDM tubing for windshield washers, vacuum and
emissions systems for power accessories. Similar to SAE J1037
specification. Will not deteriorate from heat, weathering, or ozone.
Maintains its flexibility even at low temperatures.
Specification: Similar to SAE J1037
Branding: None
Cover Color: Black
Tube: EPDM
Reinforcement: None
Temperature Resistance: -40°F to +257°F
Anyway, I am leaning towards silicone hoses for my vacuum system hose replacement. The advertisment hype for them is that they have a wider temperature range and are claimed to never harden or crack. They are available in different colors and wall thicknesses, and there are specific kits available for mustangs, corvettes, and various european sports cars. No kits for the Ford trucks, but places sell it by the foot. I haven't heard/seen of anyone else using silicone vacuum hoses on their Ford truck.
The original Ford color-stripe hoses have held up very well for a long time, but I don't know what they were made of and same-type replacements are not available anywhere I can find. It could be they were made in a time when better-performing ester plasticizers were permitted in industry, now outlawed due to environmental regulations. But that is speculation.
That's about the end of it for me. Sorry I highjacked your thread Lariat, thanks for starting it.
I can just imagine how much time it will take to undo the damage caused by that era
. I am 62 and for me, the salt of the earth type person, drove an old Ford Pick-up. Took care of his employees. And believed in America. Unfortunately those 3 things have all gone out of date.You can mimic those lines with a good vinyl dye if desired.
The color codes of those lines should correspond to the emissions label on the radiator support if your label is in color. Some unfortunately from the early 80's are black and white.
From memory from my 1981:
Yellow is vacuum advance
Blue is EGR valve from carb to PVS.
Green is EGR valve from PVS to EGR valve.
Etc...
. I am 62 and for me, the salt of the earth type person, drove an old Ford Pick-up. Took care of his employees. And believed in America. Unfortunately those 3 things have all gone out of date.Ford Trucks for Ford Truck Enthusiasts
SEM Products :: Vinyl Coat
EDIT: I see some of these colors are available in low VOC http://semproducts.com/product-catal...gs/color-coat/
Still don't know that they are compliant in Cali.
Did you ever take the truck to a different shop like I suggested.
Here's my engine with the color tape around the unmarked rated vacuum hoses. Infact you see the one that is completely red for the choke stove? That is a Ford factory hose. So them saying it has to be black and marked is quite absurd.
You see the hose with the yellow stripe in this picture going into the air pump?. It was dyed from the factory that way. It even has a motorcraft part number in yellow dye. CX-298
I would love to have your smog shop tell me I can't have colored striped hoses, because they all have to be solid black, or all the hoses have to be black, when factory original they were colored, like the Red hose in the first picture.
With the motorcraft number in possession, on the hose itself, I'd take it to the refferee, and the refferee would have that smog shops license pulled.
I would seriously go to another smog shop...
EDIT: I see some of these colors are available in low VOC SEM Products :: Color Coat
They can really help rejuvenate a weather worn cockpit.
And seem to hold up amazingly well in that environment.
Plus, boats tend to have much brighter and more colorful interiors.
I have never seen a 1/4 vacuum hose with a rating or a mark on it of anykind before, even from Ford factory. Only if it's reinforced 1/4 Fuel/emission hose. There are many factory equipped hoses that have no marks on them of anykind. California cannot force you to put something on your truck that did not come that way from the factory. They can force you to fix everything that doesn't work though.
I've owned my 1981 for over 20 years of smog checks and never had a problem with my vacuum hoses not being marked for ratings or for having colored tape on the ends to mark where they go. The Factory originals were plastic color vacuum tubing that rotted away. I just got a smog check done in April of this year. They got me for two catalytic converters this year. After that no problem. Not even a mention about the rubber hoses at all.
Well, I hear you there. California seems to be the worse offender of all states.
That just reminded me of them.
