Driveshaft slip yolk deviation... can this be right? (vid)
Old Jul 1, 2011 | 09:44 AM
CPUNeck's Avatar
CPUNeck
Ok, I'm running down a vibration more like hop you get from a choppy road, and backlash between accel and deccel. It's a single solid driveshaft, longest before you have to have a two piece unit. So while capturing footage for that I saw this! WT% I'm sure most haven't seen it, but hoping you guys that have dyno'd or something may have. Is it time for a drive shaft?
Oh and pardon the inverted video, dang mount wouldn't cooperate.
<iframe src="http://www.youtube.com/embed/uuD2rI2slcQ?rel=0" allowfullscreen="" frameborder="0" height="349" width="560"></iframe>
Old Jul 1, 2011 | 10:00 AM
SteveH-CO's Avatar
SteveH-CO
Thanks for posting the excellent video!
I'm not surprised that the d-shaft does that much in-and-out. I have lubed mine twice and have given up on having a smooth launch. Mine binds when hot and unloaded. It clunks/sticks less with a trailer in tow or a load in the bed. In cold weather, mine is fine. I think my spline fit is too tight.
I have fought sticky slip yokes on every Ford truck I have owned (1976, 1990, 1999, 2001), and figure it's the nature of the beast.
Old Jul 1, 2011 | 10:56 AM
clintbonnie's Avatar
clintbonnie
Have you ever trying using No.2 Mystik JT6 Hi-Temp Grease with Moly.. ? Great for shock load service and great for rust and corrosion..
Old Jul 1, 2011 | 02:51 PM
camodown's Avatar
camodown
I would think you would get less movement with the driveshaft slip yoke at the carrier bearing. Your asembly is backwards from mine, where mine has the balance ring on the driveshaft at the differential.
Old Jul 1, 2011 | 03:06 PM
PaysonPSD's Avatar
PaysonPSD
Looks like what happens when the slip yoke binds during fore and aft travel and has caused an enlargement of the spline race. There is orbital flexing rather then a straight line in and out travel. Disconnect the drive shaft at the diff and see how much flex there is between the spline and spline race. It should be very minimal. MHO
Old Jul 1, 2011 | 03:54 PM
cj45lc's Avatar
cj45lc
Mine is like said above, makes me wonder if someone put the driveshaft in backwards.
Old Jul 1, 2011 | 04:16 PM
nlemerise's Avatar
nlemerise
Well, either CPUneck's driveshaft is in backward OR the driveshaft in my F350 has been in backward for years (I do have the longbed CC though) and never gave me a bit of problem (If I am seeing his video correctly...on the right side of the video that is the rear differential correct?)...think I'll go buy a lottery ticket if mine has been in backwards all these years.
Old Jul 1, 2011 | 04:26 PM
cj45lc's Avatar
cj45lc
I believe I'll join ya, mine has been backwards from his for 190k miles...lol
Old Jul 1, 2011 | 04:32 PM
PaysonPSD's Avatar
PaysonPSD
My SC E99 SWB one piece drive shaft is oriented the same as Casper's.
Functionally it doesn't matter which way it is oriented.
The difference is probably SWB one piece or LWB two piece rear drive shaft.
Old Jul 1, 2011 | 04:36 PM
tdpower's Avatar
tdpower
Maybe it's a 2wd vs 4wd deal. I don't know if they are different or not.
Old Jul 1, 2011 | 04:43 PM
nlemerise's Avatar
nlemerise
Well I guess I won't buy the thousand lottery tickets then ...
Old Jul 1, 2011 | 04:57 PM
cj45lc's Avatar
cj45lc
I thought a one piece meant it didn't have a slip yoke
Old Jul 1, 2011 | 07:18 PM
PaysonPSD's Avatar
PaysonPSD
By one piece I mean it only has one drive shaft unlike the two piece drive shaft that has a carrier bearing between the front part and rear part of a two piece drive shaft.
Old Jul 1, 2011 | 09:05 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
I have never seen a driveshaft "backwards" like that, even on short beds or excursions. But then again I had never seen an Excursion with a GPR rather than a GPCM until 2 weeks ago either.
Old Jul 1, 2011 | 09:09 PM
beanhead6D5's Avatar
beanhead6D5
Here this will fix it.Riffraff Diesel: One Up Offroad Weld-On Traction Bars
