yep did a coolant flush a few weeks ago and after towing my fifth the weekend the fan kept coming on and off ,it was a 105 temp outside so I thought it was because it was so hot. The ect was @ 192 but the eot was 252 @ it's hottest after awhile of towing then back to 240 and then fan would shut down. but I never paid much attention to eot until I noticed the fan coming on and off and simply for the fact that I had done the flush myself just as a maintenance thing at a 100,000 miles. strange though the coolant temp stays constant and trans temp stays constant, are these eot's normal or high? Never had a problem or don't know if I have a problem. Also didn't use ford gold coolant used what advanced discount auto recommended for coolant for fords.
Sounds like you have a oil cooler plugged up. What coolant did advanced recommend? I can't think of anything they have that is compatible with your truck. I would get rid of that stuff quick, and don't use anything other than ford gold, zrex g05, or a cat ec1 certified elc!
I think they got this way after the flush. I have a bully dog gt to monitor the system with but I am not sure of previous oil temp. Normal drive today with no load was 192 ect and 222 eot for 50 miles stayed the same consistantly though.yeller looking stuff that I got from discount auto, It said that it worked for ford diesel too.I guess I'am a sucker. But just never heard of doing a coolant flush and have a cooler problem after.It was very clean system, just thought after 40,000 it should be changed. But I take the advice well. Didn't do a complete flush just drained the sytem filled with water drove till temp and flushed three more times like this then added coolant and water.
Look in the tech folder for a good explanation on how to flush the coolant system. Sounds like you have a plugged oil cooler. One more thing to check is your temps first thing in the morning after a cold soak. Just to verify you don't have a bad sensor. After at least a 12-15 hour cold soak (motor not running) the ect and EOT should be the same or no more than a degree or two difference. If they look good then I would not drive the truck anymore until you change out the oil cooler. Driving with a plugged oil cooler will cost you a lot of money if it goes out completely.
You definitely need a new oil cooler, you have a 30 deg. spread just driving unloaded. Depending on what year EGR cooler you have, you might want to replace that also.
Do ya think just because I am using the old discount auto coolant that might be the reason for the higher oil temps or just by dropping the lower hose and clean water flushing several times would have plugged the oil cooler , I'am pretty sure I didn't have these temp problems before the flush or my fan would have or should have come on before? Could the flush cause this? didn't pull blocks plugs cause I couldn't find them. Or maybe just flushing again and putting the good stuff back would help? Thanks for all the advice just got the dang thing paid for and seems like it just started acting nasty.It's like it new what the payoff day was and it was out of warranty, but has been great until then
I dont see a couple of water flushes drain and fill causing to much problem
I think it could be the type of coolant your running
but hard to say since you didnt see temps before
most people that clog there oil cooler after a flush used chemicals to break the junk loose and flush it out but usualy just gets stuck in the oil cooler
The coolant passages in the oil cooler are half the size of the oil pssages so its easy to clog
stick around here lots of people have helped me with stuff and LOTs of great info in the tech folder
welcome to FTE
Thanks for all the help! Got to get the rv back home from a short distance away and I will keep a close eye on temps then I'll see what I can do to fix.
Try to backflush your cooler.there's a cover under the outlet of the turbo you can take off and stuff a piece of clear hose in there and remove the driverside block plug,and the lower rad hose and let it flush for an hour or so.do a search on it.its worth a try.I went from 27* spread at 70 to 18* after flushing,but went back to ect178,eot 247 empty after a week.ended up doing a cooler to find my radiator has got my cooling system on a constant diet of scale.good luck to ya,changing the cooler is a piece of cake,the hard part is making sure the cooling systems clean
