Sponsored by: Real Truck
Firestone Air Bag Compressor Install
Old Jun 30, 2011 | 12:22 PM
gregb89441's Avatar
gregb89441
I'm trying to find a place to install a Firestone Air Bag Compressor in my 2010 F350 Lariat Diesel 4x4. Under the hood is out of the question - you couldn't fit a matchbook under there. Inside the cab???? Where???? Anyone out there already install one of these?
Old Jun 30, 2011 | 01:32 PM
wizardsr's Avatar
wizardsr
I put mine behind the crew cab rear seat and ran the tubing down through the floor to the air tank.
Old Jun 30, 2011 | 02:06 PM
gregb89441's Avatar
gregb89441
Thanks for the idea, however, I've completely removed the rear seat out of my crew cab (needed room for dog crates). I'm thinking my only option may be up under the dash somewhere - maybe up on the firewall behind the brake pedal).
Old Jun 30, 2011 | 04:58 PM
Firefighter 1406's Avatar
Firefighter 1406
I mounted mine under my ext. Cab seat, but since you have a crew cab and no seat, you might be able to fit it behind the pedals. It will be a tight fit I think but might work. The only other option is on the frame rails but then you have to worry about rust.
Old Jun 30, 2011 | 05:20 PM
Kajtek1's Avatar
Kajtek1
I have regular cab and lot of stuff I carry behind the seat, so I have my fill up connectors with gauges bolted to the floor between the seat and the door and keep the compressor in the outside tool box. Whenever I need to inflate the bags, it takes like 45 seconds on the parking lot. Since I also have air bags on my trailer, I just move the same compressor to the trailer.
Old Jun 30, 2011 | 05:25 PM
william_04_x's Avatar
william_04_x
Mines mounted on the inside of the DS running board. Been there for 7 years now and no problems.
Old Jun 30, 2011 | 07:27 PM
dualwheels66's Avatar
dualwheels66
Mine is on the outside of the frame rail. I have had the compressor for 6 years and on 3 different trucks, no problems.
mwsF250's Avatar
mwsF250
I put my compressors under the bed, mounted to frame. Built a steel and aluminum box to protect them. The box is vented (even has an 8" fan for when both compressors are working hard), but in a way that very little spray or dirt can get in.
Old Jun 30, 2011 | 08:36 PM
RV_Tech's Avatar
RV_Tech
Several of the class C motor home manufacturers mount them on the frame rails and they seem to hold up pretty well. I had them there on two motor homes and did not have any problems. A cover may be a good idea for added protection.
Steve
Old Jul 1, 2011 | 10:03 AM
gregb89441's Avatar
gregb89441
Thanks for all the suggestions. The more I look at this, the more I'm thinking that a frame rail installation will be the way to go for me.
Old Jul 1, 2011 | 10:52 AM
senix's Avatar
senix
Mine is on the fuel tank bracket. The short beds have a bracket right in front of the tank. I put it up there.
Old Jul 1, 2011 | 10:56 AM
gregb89441's Avatar
gregb89441
Thanks Senix. I'll take a look, but I had the original tank removed and replaced it with a TFI 47 gal tank. Not sure what the bracket looks like now.
Old Jul 1, 2011 | 11:00 AM
senix's Avatar
senix
Here are my pics of my install:
Ford Truck Enthusiasts Forums - senix's Album: air bag install
Old Jul 1, 2011 | 11:07 AM
gregb89441's Avatar
gregb89441
Looks like a pretty clean install. I hope I can find a spot up underneath that will work, and still protect the compressor. Thanks.
Bigpipes 35
All Things Towing
22
Oct 3, 2016 09:47 AM
acf6
Jun 9, 2013 05:44 PM
Fear no Hill
6.7L Power Stroke Diesel
Dec 13, 2012 09:18 PM
MisterCMK
15
Apr 17, 2008 10:14 AM
