buzzing in solenoid
Old Jun 30, 2011 | 11:35 AM
gravel pit camper's Avatar
gravel pit camper
buzzing in solenoid
i just replaced the solenoid on my 87 econoline 27ft motorhome. i used a heavy duty battery charger set on engine start, but still getting a buzzing from the brand new solenoid. without the charger, i'm getting no sound whatsoever. pls any suggestions? thanx
Old Jun 30, 2011 | 01:17 PM
subford's Avatar
subford
A buzzing sound from a solenoid means there is low voltage to the coil of the solenoid.
My guess would be a bad battery or battery cables/connection.
The charger needs a little help from the battery and if it gets none you will have what you have. Even a battery charger with a start (boost) position on it.
Old Jul 1, 2011 | 11:21 AM
gravel pit camper
buzzing solenoid
Thanx for the info. I was suspecting that was the problem, but not real great at mechanical work. Thanks again
Mikey1996
Jul 18, 2016 07:36 PM
petree
Apr 28, 2016 09:28 PM
izmepeggy
27
Oct 28, 2015 05:05 PM
octaneforce
15
Oct 30, 2011 10:22 AM
tdpower
19
Feb 1, 2009 11:05 AM
