Help! power steering hose went
Old 06-30-2011, 07:05 AM
78f3504x4's Avatar
78f3504x4
78f3504x4 is offline
I started her up this morn ('95 PSD) and this hose spit right out of the fitting followed by p/s fluid. Do I need to replace the whole hose or get a new fitting put on? Money is tight...
Old 06-30-2011, 07:12 AM
540milotalon's Avatar
540milotalon
540milotalon is offline
The high pressure hose needs to be replaced/repaired properly. The return or low pressure hose can be repaired with a clamp sometimes. Not sitting here looking at my set up your pic looks like the Hi pressure side.
Old 06-30-2011, 07:15 AM
Copedawg's Avatar
Copedawg
Copedawg is offline
Same EXACT thing happened to me...I started it up and heard a "POP" but still had power steering and charging etc..(I was hoping it was a belt)...It was the bottom hose. I went to "Track Auto" and got a replacement hose (about 40 bucks I think), replaced it added some PSF turned it all the way to the left and right pumped the brakes a few times, topped it off and it has been strong ever since. Easy fix
Old 06-30-2011, 07:24 AM
Copedawg's Avatar
Copedawg
Copedawg is offline
Here is my thread when mine went: https://www.ford-trucks.com/forums/1...xtra-time.html No other info really. Oh, I would bring the old one with you...there are a few sizes. good luck!
Old 06-30-2011, 04:48 PM
DZL JIM's Avatar
DZL JIM
DZL JIM is offline
PREMIUM SPONSOR
Pretty common thing.
If your truck was built after Aug 12?? '97 or so it will have a different hose that the parts stores usually don't stock.
Otherwise all the local stores here have the older ones in stock, which you should find for your '95.
Price isn't too bad and definietly not worth trying to repair the old one
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old 06-30-2011, 07:19 PM
rolltide3006's Avatar
rolltide3006
rolltide3006 is offline
I'm at autozone right now and they have the hose for $25. Mine just started spraying out. I think it is the orings. When I took it off there were 2 orings- a white hard plastic one and a black rubber one. Do I news both on there?
Old 06-30-2011, 07:29 PM
Copedawg's Avatar
Copedawg
Copedawg is offline
I don't remember the "Pacifics" but I would use what ever it comes with. Ifr it comes with 2 I would use them both....if they are different sizes
Old 06-30-2011, 08:13 PM
forrider's Avatar
forrider
forrider is offline
i bought a new hose for mine from auto zone it wasnt the right one so i had to flare it with my machine but all was good after that i pulled up in my driveway and it just popped it out funny thing is mine is a 95 too lol hope ya get it fixed
Old 06-30-2011, 08:31 PM
rolltide3006
Not trying to high-jack the thread- How many o-rings does the high pressure line have on it? Mine had a black rubber one on it and a white plastic one also.
Old 06-30-2011, 09:30 PM
RRranch's Avatar
RRranch
RRranch is offline
The white one is a back up ring to keep the o ring from blowing out. Some use it, some don't. If the threads and flare are the same then it will work fine.
I saw one of you say you paid 40 bucks for the bottom hose. You got ripped. It's nothing more than 3/8 transmission cooler line. I also very highly recommend putting a 3/8 inline transmission filter on it when you have to replace it. They are cheap insurance.
If you got a whole bottom hose with a new cooler and everything that wraps around in the crossmember then seriously you wasted your money. Next time just cut the metal tube right below where they crimped the hose on and hose clamp a new hose on with that filter in the middle. It's just a return hose. Absolutely no pressure on it.
Old 06-30-2011, 10:16 PM
78f3504x4's Avatar
78f3504x4
I picked up a high pressure replacement hose from my local parts store. They had it on hand. $27 and good to go. It was a one-beer job. I had to re-use the fitting from the old one (see pic) that screwed into the p/s pump. Thanks for the help guys.
Old 07-01-2011, 04:29 AM
Copedawg's Avatar
Copedawg
Copedawg is offline
Glad to hear you are up and going for the Holiday weekend!
Old 07-01-2011, 06:18 AM
DZL JIM's Avatar
DZL JIM
DZL JIM is offline
PREMIUM SPONSOR
Not true for all of us living in the salt/rust belt.
Them dam things rust through as easily as brake lines do.
Also, if you run larger tires, you can drill out that fitting that goes into the pump just a hair more, maybe 1 drill size, and you won't believe how easily your steering turns.
I did that on my '96 with 33" tires about 10 years ago and it's quite different from my stock '97.
__________________
Old 07-01-2011, 07:15 AM
Talyn's Avatar
Talyn
Talyn is offline
The line blows because its a poor design and rusts inside the collar.
Spray it down with fluid film before install. =)
Talyn's Avatar
Talyn
Talyn is offline
Fluid film will keep it from rusting Jim. =)
Quick Reply: Help! power steering hose went
