General Diesel Discussion
Old fuel
Old Jun 30, 2011 | 05:49 AM
KC8QVO's Avatar
KC8QVO
Old fuel
I have a 5 gal can I had from my last truck. How should I dispose of it? I need to take the can, and some fresh fuel, on my trip next week just in case.
Old Jul 1, 2011 | 07:59 PM
dschuffert's Avatar
dschuffert
Not the most politically correct solution but I use old fuel (usually a few gallons a year in volume) and pour it on my gravel driveway where the foliage is starting to grow back. My driveway is a little over 400 feet so it is dispersed over a large area. I don't think the ecology or any animals are harmed in this scenario.
Old Jul 1, 2011 | 09:21 PM
joshofalltrades's Avatar
joshofalltrades
I would dump it in your tank a gallon or two at a time and burn through it, or if you don't trust it at all, use it to start a bonfire when needed
Old Jul 8, 2011 | 05:52 PM
gandrimp's Avatar
gandrimp
How old is it? Diesels good for 2 years. More if stored right.
Old Jul 16, 2011 | 10:13 PM
dyoungen's Avatar
dyoungen
I bought a 1986 trooper that had set for 6 years back in 2004. All I did was put a battery in and with fuel that was 6 years old, turned the key and she started right up. If your unsure, add it slowly but with the cost of Diesel, I wouldn't throw it away
Old Jul 17, 2011 | 06:08 PM
sandmanf250's Avatar
sandmanf250
old fuel
dump it in when you fill up and don't worry.
Old Jul 17, 2011 | 10:24 PM
KC8QVO's Avatar
KC8QVO
I ended up giving it to a farmer for his self propelled sprayer. That made short work out of it.
I thought about mixing it in with fresh fuel in my tank but I didn't want to run it through the engine and all the filters. It was about 10 months old and I figured it wouldn't be good. My co-workers didn't seem to bat an eye at it when I was asking them what to do with it. They both said they'd take it if their trucks were close. We ended up just letting the farmer throw it in his tank, after all farm diesel is LSD and the engines can take harder use than the new ULSD-only on-roads with all the emissions stuff.
Old Jul 18, 2011 | 06:54 PM
renoduckman's Avatar
renoduckman
old fuel
At work we have fuel for out diesel generators thats been in the tank for 10 years or more. Its been treated once or twice but still runs fine when we test the generators monthly.
Old Jul 18, 2011 | 07:55 PM
RRranch's Avatar
RRranch
Farm diesel hasn't been LSD in several years now. Throughout the country. Lots of farmers still think it is but it isn't. Our distributor still tells me it is too but I called the company he gets it from. They said it's not and the law in texas had it phased out 3 years ago.
I would have used 10 month old fuel in anything but since I usually get bio diesel now I wouldn't use it past 6 months. The stuff in my farm tank now is that old and the tractor is running like crap on it. It's running perfect on fresh bio. I usually spray stuff like that in my driveway too or use it in the sprayer as a sticker. Helps make chemicals stick to weeds.
Old Jul 18, 2011 | 10:54 PM
dyoungen's Avatar
dyoungen
Back when I was making my own biodiesel I didn't think twice about using old biodiesel. I didn't let it set in the fuel tank of the vehicle I"m driving for long as I used it driving it dailly. It does continues to settle out the glycerin for a long time. I mixed a batch for a guy I borrowed some but after 2 years I couldn't contact him and needed the barrel so I poured it into the fuel tank and it didn't miss at all. I do know if you put it in a vehicle or something that sits for long periods of time it will continue to settle out and yes it will gum up the filters.
Old Jul 19, 2011 | 06:43 AM
RRranch's Avatar
RRranch
My tractor was weird and I don't know exactly why. At PTO speed it was cutting out pretty bad on the old bio in it. We've had a bad drought going on for about 10 months now and it's been used so infrequently because nothing is growing that the fuel in the tank must have settled out like you say. Just topping it off with some regular diesel cured the cutting out problem. It was commercially made soybean B100 in it. Not sure if I'll ever buy any from that company again though. They recently switched to chicken fat and it's not running very well in their own vehicles. Their kubota tractors and engines are running rough and their 6.0 l f360 is about to cost them a fortune I think with it.
danevans
Escape & Escape Hybrid
Oct 30, 2025 08:31 AM
Larryd8563
Oct 17, 2014 02:50 PM
dooleyservices
Dec 28, 2011 03:37 PM
sportsmansteve
15
Jul 31, 2011 09:38 PM
pancake
Garage & Workshop
16
Oct 5, 2003 04:59 PM
