Help on a 96 7.3
Old Jun 29, 2011 | 09:09 PM
gatormccluskey's Avatar
gatormccluskey
Help on a 96 7.3
I bought a 1996 F-250 7.3 5 speed. It had not been ran in over two years. I but in two new batteries and filled the filter with diesel clean. I was going to turn it over to get the diesel to the injectors. I didn't unhook anything to stop it from cranking. It started right up and ran a little rough, after about 10 min it cleared up and ran fine. I drove it around town over the weekend with no problems. Today I crank it up and the engine light came on and ran like grap for about five min. It cleared up and the light went off. About twenty min later the samething. It will happen off and on.
Thanks in advance for your thoughts and replyes
Old Jun 29, 2011 | 10:36 PM
oldbird1965's Avatar
oldbird1965
It could be a thousand different things. Did you check the air filter for rats nest or any blockage? How about the motor, any signs of animals chewing on wires? If you can get the oil warmed up, change it. When it did run, did it run good? Get the codes for trouble shooting. Keep us informed.
Old Jun 30, 2011 | 12:41 AM
BuckHammer's Avatar
BuckHammer
Read the codes, and that will give us something much more solid to go on.
Old Jun 30, 2011 | 11:42 PM
oldbird1965
Must be a echo around here, LOL.
Old Jul 1, 2011 | 01:30 AM
BuckHammer's Avatar
BuckHammer
Sorry, Glenn. I only read the OP before posting.
But yeah, do like Glenn originally said and get the codes. That will do a whole lot to help us help you.
Old Jul 1, 2011 | 04:33 AM
Copedawg's Avatar
Copedawg
If you have not changed the oil/filter yet, I would do that too. We need good clean fresh oil to run properly. When our oil breaks down it starts to foam up and it won't right.
Old Jul 1, 2011 | 08:43 PM
MONAVIERONJON's Avatar
MONAVIERONJON
any consideration of algae in the tank ,perhaps fresh fuel that might not gunk up the fuel system Echo x3 on that pull codes for assistance
Old Jul 1, 2011 | 10:01 PM
oldbird1965
Algae is a possibility but I stored a 81 Jetta diesel for ten years and it fired right up and ran for months with no problems. Do that with a gasser.
Old Jul 1, 2011 | 10:21 PM
MONAVIERONJON
algae or sediment to the effect of gunkin up the fuel system,bowl,screen.Seems like there are quite a few approaches to this one
Old Jul 1, 2011 | 10:26 PM
oldbird1965
I forget what that stuff is that you put in to fight Algae.
Old Jul 4, 2011 | 07:26 PM
gatormccluskey
O.K. I had time to mess with truck a little today. Had a friend of mine, that works for Ford bring his scanner. # 1 and # 3 not firing. O.K. twenty of yall jumped up yelling > I Know > I Know. Yep harness fried. He took the oil cap off and with a light, you can see it.
So next weekend I will be working on the 96.
He wanted to buy it. I told him no, untill I get to fix it !
I ask him what he thought it was worth. If he thinks its worth that much, he can have it, when I'm done.
Thanks for all of you responding.
I will keep yall posted.
Old Jul 4, 2011 | 08:22 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
An algaecide sorry I couldnt resist Glenn.
In other way if he had algae he should have seen it in the fuel filter= BLACK FILTER.
Old Jul 4, 2011 | 09:57 PM
oldbird1965
Algaecide huh? I wonder if they make a wifecide??
Old Jul 4, 2011 | 09:58 PM
gatormccluskey
If they do, I want 5gal.
Old Jul 5, 2011 | 09:09 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Whats is the e-mail of your wife?
Same question to you.
