I am needing a new fuel sending unit for my '84 F350, but I'm having trouble finding one like I have. This is for my front tank along the drivers side frame rail. Mine has a supply tube and a return tube on the top of the sending unit, and a 3 prong plug for the electrical connection. All the parts stores I have checked with, and also a few sites online, only list one with ONE outlet tube and NO return, and only a 2 prong plug.
If mine is for EFI, then will it have a fuel pump in the tank? I haven't taken mine off, but I know the original 460 had a mechanical pump. Also,, I looked at Rock Auto.com, and the plug it shows in the picture is rectangular with the terminals in a row, not round with the terminals in a triangle shape as mine is. I was hoping to buy a new one before I pulled my tank. Might not happen that way.
Also to add, check your block to see if there's a mechanical pump there, if no, then it's in the tank. I try not to speculate on what people have since these things are getting up there in years...
Hmmm,,,,, you're good! Not sure why, but if my sending unit has a pump in the tank, the Bronco unit will fit. Just don't understand someone making that kind of change. Only thing I wonder about it that my wiring is correct, and hasn't been spliced that I can see. BUT.... did the Bronco have a side tank? When my sending unit was working, it was very accurate.
My engine had a mechanical fuel pump when I bought the truck, and the steel lines were running up along the frame as they should be. I pulled the 460 and installed a 5.9 Cummins and 5 speed, so I do need the fuel return line for the diesel.
OK, I need more information to be able to find a Ford OEM replacement (if I can).
I can see in the parts catalog that some F250s/350s ever since 1980 had electric fuel pumps.
But reading that the 460 has or had a mechanical pump concerns me, I don't know if perhaps some had BOTH or not. Quite honestly, I would suspect not.
So, let me ask... is the stock factory wiring set up to accommodate an in-tank pump? I read about the old sending unit have a triangular-shaped collection of 3 electrical connections, is there a factory-supplied mating electrical connector in the wiring?
I also need to know:
Size of tank (in gallons)
Location of tank - inside or outside of frame rail
Steel or plastic tank
Wheelbase length
I'll warn you and say I looked up the availability of some of those in-tank pump/sending-unit-assemblies, and it doesn't look good.... It looks like at least one of them has been superseded (replaced) by a different Ford part number, and I have no way of looking up that number, we'd need to get NumberDummy involved if he can help.
But, the presence of factory wiring (or not) for such a device will be most telling, followed by the other questions......
my 86 f350 with 460 had electric pumpus in both tanks, from the factory. they were different than the efi pumps tho, I cant remember anymore why, but you can nolonger get them. (at least I couldn't) I wound up putting a holley electric pump in the rail, and only using 1 tank
The pump isn't my issue,,,,, knowing how much fuel I have in my tank is. My sending unit is sporatic right now,, so I track my miles, and when I get around 225 on it,, I fill up. I'm getting around 18 mpg, so I'm confident that this leaves a buffer. I know when the gauge was working properly, I have gone over 300 miles on a tank (19 gallons), but I don't chance it now. I hate walking.
I will check with Advance Auto Parts or Napa tomorrow to see what can be found. If not,, the link for O'Reilly's will work out.
thanks again,
No, the Bronco didn't have a side tank, but that doesn't mean someone didn't make it work (I'm not sure of length differences off hand) or that it isn't off something else entirely. Your best bet is to pull the sending unit and verify the diameter of the sending unit hole on the tank, 1980-84 is 2" and 85-86 is 3 5/8". As to why people would do it, it might of been something they had lying around or all that they could find.... People do what they can to keep stuff running.
if it works sometimes, the float is probably bad. that being said, early modles had a brass float, later had plastic. you can still get floats, but only the plastic version.
I would keep that truck forever if it gets 300 miles on a front tank. All my gas powered trucks through all the years,, and none have ever done that. My 460 was 10 mpg.Loaded, empty, over the road, 10 mpg.
My truck HAD a 460,,, 7.9 MPG. Now it has a 1990 5.9 Cummins, POD injectors, 4" pipes, and the pump is turned up. Does great. Turns 2400 rpm at 70 MPH with 4.10s. I also have 2 F150s with 300/6s,,, @ 15MPG on those.
The gauge was very accurate, but now, once it gets to about 3/8 of a tank, you are walking. And I do plan on having this truck for quite a while. Just need to get a few bugs worked out of it.
I checked the sending unit hole on my tank, and it is 2". So it is a 1980 - 1984? Any idea what the sending unit for a diesel looks like?? I can add a return line and rewire if necessary, but I really hope to find one that is suppose to fit it.
what did the float look like? did you take it off the unit, and shake it to see if there is liquid inside? does it bubble when you hold it under water?
