Needing a fuel sending unit
Old Jul 2, 2011 | 04:53 PM
Fummins's Avatar
Fummins
I may have just figured it out. I plugged the sending unit in, and checked the gauge through full range of motion. Full to empty, it was working great. Then I noticed when I was moving the sender, the pickup screen on the bottom of the unit was spinning to the "downhill side" When it was under the float, it wouldn't quite go down to a quarter of a tank. I think as the fuel was sloshing around in the tank, it got caught under the float, and was stuck there. Hope so,,, cheaper than a new unit, but a pain in the *** to pull off without dropping the tank all the way. Ordered a new o-ring (the old one was leaking) to be in on Tuesday, so will leave it off til then. Will let you know when I put it back on.
thanks for all the help.
Old Jul 2, 2011 | 04:55 PM
dustybumpers's Avatar
dustybumpers
very good, I hope it cures your problem
Old Jul 2, 2011 | 09:17 PM
ctubutis's Avatar
ctubutis
If you have the sender removed from the tank, open it up and look inside and make sure the insides look OK.
There is a brass wiper-like thing that glides up & down a piece of material around which is wound a VERY fine wire, that wire eventually wears through and the wire unravels.
BTW I looked in the FoMoCo parts catalog, that sender is not original to that truck, somebody swapped that in.
hharris8
Mar 24, 2017 06:13 PM
MFplowboy
Feb 13, 2017 06:35 AM
ssemones
Dec 31, 2015 07:35 PM
oneofakind97
Jul 25, 2015 09:27 PM
Tuba25
Mar 19, 2015 11:46 PM
