Need front leaf spring advice
Old Jun 29, 2011 | 11:39 AM
Brown Falcon's Avatar
Brown Falcon
Just so you guys know what I'm doing...
I'm getting ready to do a 4x4 conversion on my '95 F350.
I will be using a Dana 60 front axle with a 3" RSK
What are the best springs to use and how hard is it to find them for sale? I don't want to spend a bunch of money on springs.
I've heard the some Superduty leaf springs ride better (I don't care about ride much), but they are longer. What do you have to do to install them? Which Superduty's can I get them from? And how much are they usually?
My other option is stock springs from an OBS. I have a set on my '87 F350 I'm parting out that would work. Would it be better to just stick with stock?
Old Jun 29, 2011 | 12:33 PM
superduty4x4's Avatar
superduty4x4
I'd just get stock OBS F350 front springs. The SD springs require moving the front of the RSK mount forward and cutting the bumper, and it looks hacked IMO.
Old Jun 29, 2011 | 12:48 PM
Talyn's Avatar
Talyn
IIRC, you gotta move the rear mounts as well. But I'm not 100% on that. Thats what it sounded like neal was telling me.
Most just shim out their front bumper to make room for the RSK.
but its the V-Code springs outa the SD's.
Usually about 300 I think.
I'm with chase, just grab some 350 springs and take it easy.
Old Jun 29, 2011 | 01:00 PM
DIYMechanic's Avatar
DIYMechanic
^^^x3. Especially if you're not too particular about the ride firmness. I like the way mine rides. Feels like a truck!
Old Jun 29, 2011 | 02:51 PM
bryanlindborg600's Avatar
bryanlindborg600
I have a set of front springs off my 97 f350 with an add a leaf in them, but I am in washington state...just throwing that out there
Just re read and saw your in oregon, I'm in northern washington about 1 1/2 north of seattle.. the springs are just takin up space, if you want them I'm sure we can reach a fair deal...?
Old Jun 29, 2011 | 03:29 PM
GreaseMonky's Avatar
GreaseMonky
What did the v-code sd springs come out of?
Old Jun 29, 2011 | 06:28 PM
Brown Falcon
I'm just trying to decide if it's worth taking the front axle out of my '87 just to keep the springs from it.
It's a F350, appears to still be the F350 springs, but has a Dana 50 axle in the front.
Old Jun 30, 2011 | 01:28 PM
Tom S's Avatar
Tom S
I agree that it is not the best design once you move to SD springs. The project with Precision Metal fab for a different kit is moving foward!
Old Jun 30, 2011 | 01:43 PM
Neal 97 250's Avatar
Neal 97 250
In your case I would use the staock F-350 springs if you have/can get them. The SD springs are longer and require you to move the front bracket forward, cut the bumper bracket and relocate and most likely have to cut the bumper as well. You can't shim the bumper enough and look decent.
I just did the SD springs and RSK and if I were you I would just use old body style springs. Way easier for sure. SD springs do not make it ride all that great, it is still a truck.
Old Jun 30, 2011 | 01:47 PM
superduty4x4
Good to hear! I think that will make the SD spring swap a much better option.
Old Jun 30, 2011 | 02:15 PM
BadDogPSD's Avatar
BadDogPSD
The crew cabs w/ 7.3's.
Old Jun 30, 2011 | 04:52 PM
Brown Falcon
Well, I'm going to stick with stock OBS springs.
So now the question is to fab up a stock style shackle mount, or do the 3" RSK?
I'm using stock 4" lift blocks in the rear and a Dana 60 front... I just don't want a "Cali Lean" with the front higher than the rear. Will the 3" RSK raise the front too much?
sevensecondsuv
Feb 25, 2017 11:26 PM
OldRacerGuy
Jan 29, 2017 11:44 PM
Alec Blanchard
May 12, 2016 10:25 AM
Dirtyweekender77
Jul 17, 2014 10:47 PM
hasteranger
Apr 27, 2012 06:14 PM
