My 04 Short Dual Crew Diesel automatic has a dark grey plate in the upper dash that holds the electric rear window control. I want to mount my banks computer in this space and move the switch to the lower panel where there is an unused cutout for it. When I pulled the plate outofthe dash, there are TWO connectors attached to the backside.... One is the window, the other is fourwires into a white plastic rectangle... it does not go thru the plate.
Sorry about no pics, butwhat is this smaller connector, and can I ziptie it out of the way?
Do you have 4WD? The electronic 4WD switch is in that area.
There is also an optional Passenger Airbag Deactivation switch on extended and regular cab trucks, but it's pretty far to the right of what you are describing.
Either way, I don't see why it can't be zip tied out of the way.
