Valve Cover??
Old Jun 28, 2011 | 05:52 AM
Bully350's Avatar
Bully350
Valve Cover??
OK so I took my valve cover off my 83 f350 with a 460. I painted them and got all the old gasket out. they seem to be in good shape and and "crimped" edges. I put the new rubber gasket on one and when I get to the last two bolts are just off a little. So should I just manipulate them? or try something else?
Old Jun 28, 2011 | 12:48 PM
Franklin2's Avatar
Franklin2
Flip the gasket all around to make sure you have it installed correctly. If that's ok, the gasket may need to be "stretched" a little bit for the bolts to fit. It should not be off so much that you have to whittle on the gasket holes though. I would take them back if that's the case.
Old Jun 29, 2011 | 06:40 AM
Bully350's Avatar
Bully350
It is like it is just a smidge to big.. someone said to do the four corners frist and then the middle bolts and that should take care of it... so will try that,,
Old Jun 29, 2011 | 10:17 AM
Shark Racer's Avatar
Shark Racer
Did you make sure to install the rubber winglets into the slots on the valve covers?
Old Jun 29, 2011 | 12:14 PM
Bully350's Avatar
Bully350
Yep Wings are all in..
sboyden88
Jan 4, 2012 04:49 PM
tunaman
May 14, 2011 12:23 AM
timbersteel
May 12, 2011 06:29 PM
Shark Racer
Jan 10, 2011 02:41 PM
86.9
Oct 5, 2010 11:16 PM
