1978 - 1996 Big Bronco
1994 bronco problems
Old Jun 27, 2011 | 06:53 AM
BrandonBronco's Avatar
BrandonBronco
I have a 1994 bronco that just had the engine rebuilt. After 3 months of running great it started sputtering and backfireing. I replaced the fuel pump and filter. I next replace the EGR valve line because i notice it was rusted and broken. After I replaced the line I took it for a small test drive and when I pulled up to my house the back side of the engine started on fire. PLEASE Help. My wife is gonna kill me if I put much more money in to this truck.
Old Jun 27, 2011 | 04:43 PM
Kemicalburns's Avatar
Kemicalburns
who did the work? was the motor a reman or built at a shop? did you ever pull codes? have you checked fuel pressure?
Old Jun 30, 2011 | 09:36 AM
BrandonBronco
A local guy did the work. It was a rebuild using the same block with different heads. I checked the codes and it just gave an air flow error.
The only thing left is to get rid of the catalytic conv. and check the emission crossover on the rear side of engine. Got any Ideas?
Old Jun 30, 2011 | 11:04 AM
Kemicalburns
what codes did you get? please post them up. did you count the flashes or use a code reader?
again what is your fuel pressure and what is your timeing set at with the spout removed?
what heads are on there? anything else done to the motor like a cam upgrade? headers etc..?
Old Jun 30, 2011 | 07:55 PM
greystreak92's Avatar
greystreak92
Everything Kem has asked is important and will be the ONLY way to the root of this issue.
Oh and arbitrarily removing emissions equipment will do NOTHING but screw things up further! EEC-IV computer has this equipment too well integrated to just start yanking it off the truck.
Old Jul 1, 2011 | 10:03 PM
ErrorS's Avatar
ErrorS
I've been fighting crossfires on my Bronco since I replaced the plug wires, you should check and make sure you're not getting any.
JohnDiG
Mar 7, 2004 08:43 AM
iggy1982
Aug 14, 2003 05:15 PM
badog
Jan 8, 2003 05:20 PM
ckstrawser
Oct 30, 2002 06:52 PM
RSNIB
Jul 15, 2002 10:00 AM
