Isspro EV2 question (probably dumb)
Old Jun 26, 2011 | 09:55 PM
2cylguy's Avatar
2cylguy
I am in the process of installing my 3 guage pod that I got from Clay and have read all the directions through 3-4 times. I must be stupid because I don't understand how the guages get any power. If you run the lines from the sensor to the guage, where does it get power?? Am I thick or just missing something obvious?? The only place I see anything about ANY 12v connection is in relation to the guage lights. HELP please!! Thanks, Tom
I have the 3 basic, boost, pyro, trans temp. guages.
Old Jun 26, 2011 | 10:33 PM
big poppa's Avatar
big poppa
Correction, my gauge lights are tapped into my dimmer switch, my oppoligies. I ran my power wire down under the steering collumn, theirs a thick red wire thats hot only when the key is turned on. Wished I had a pic for you. Mine are the first series EV 1 Isspros so I'm not sure if you can piggyback those EV2's, I believe you can.
Old Jun 26, 2011 | 10:44 PM
jhand124's Avatar
jhand124
I don't have Evo's but does this help.
Edit: that pic sucks I'll see if I can make it better
Heavy red wire with black trace is 12v power in top of pic. (just under the steering column.
Gauge illumination is top center wire light blue with red or yellow trace in the brown connector at the 4:00 position when looking at the panel (removed) under the steering column
Old Jun 26, 2011 | 11:55 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Give me a call tomorrow and I will walk you through it.
Old Jun 27, 2011 | 01:40 PM
2cylguy's Avatar
2cylguy
Props to Clay!! I knew there was a reason I listened to almost everyone on here and bought my stuff from him. Customer service is second to NONE!!!! Thanks Clay!! Tom
P.S. Just buy from him and don't worry about the price. It's worth it for the service!!
Old Jun 27, 2011 | 01:45 PM
superduty4x4's Avatar
superduty4x4
His prices are terribly high on most stuff though...
