E4OD Questions
Old Jun 26, 2011 | 07:28 PM
blitzkrieg469's Avatar
blitzkrieg469
E4OD Questions
my 93 tranny took a crap....picked up one out of a 90 bronco with same engine as my F-350. It has supposedly been rebuilt about a year ago. My question is.....is it possible to tell if a shift kit was installed?....I will be pulling horses and a 16' trailer full of wood from time to time and want to add a shift kit....also...since it came out of a 90....is it the same tranny as my 93? The transfer case that came with it looks different because it looks like it uses a speedo cable where as my 93 is electronic speedo...thanx
Old Jun 27, 2011 | 06:27 AM
Lazy K's Avatar
Lazy K
Transmission should be the same. Up to `91 the speedo was cable driven, from `92 it was electronic and signaled from the sensor on the rear diff, so your speedo doesn`t need the cable connection.
The only way I can think of to check for a shift kit is to pull the valve body and dismantle it.
Best shift improver is to get a Punisher valve body.
Old Jul 1, 2011 | 06:48 AM
blitzkrieg469
gonna try to put in tranny this weekend.....any ideas on what brand of fluid I should use.....trans has supposedly been rebuilt with the past year
Old Jul 1, 2011 | 07:53 AM
Lazy K's Avatar
Lazy K
Any fluid that says it meets Mercron V specs would be fine. If you want a synthetic then Mobil1 ATF would do the job.
For an empty trans and torque converter you will need around 16qts.
Old Jul 1, 2011 | 07:55 AM
blitzkrieg469
Ok...thanx
Frankthetank46
1947 and Older Ford Trucks
Nov 13, 2014 09:13 AM
nashgto8u
Aug 12, 2014 11:13 AM
Squarebody
Oct 22, 2013 12:16 AM
btacarlton
1978 - 1996 Big Bronco
Nov 7, 2007 09:50 PM
vinnyf350
Electrical Systems/Wiring
Dec 18, 2006 08:37 PM
