Intake plenum prob?
Old Jun 26, 2011 | 04:19 PM
Okidragon's Avatar
Okidragon
Intake plenum prob?
Posted Explorer prob on 6/25 (seems a misfiring prob and ambiguous prob codes). Checking vacuum lines and such today at idle. The intake plenum on the passenger side bank (where noises originate) is MUCH hotter to the touch than the right side - intake shouldn't be too hot correct?. Think this supports theory of bad injector causing a misfire vs bad sensor(s), MAF, O2, etc. Any thoughts?
Old Jun 26, 2011 | 06:01 PM
Roger1960's Avatar
Roger1960
Not sure, but if you wanted to test the theory, swap injectors left to right and see if the problem moves.
If the problem does not move, then you can swap plugs left to right and see if it moves then.
If it still doesn't move then you can continue the hunt.
Old Jun 27, 2011 | 05:58 PM
aquanaut20's Avatar
aquanaut20
Or stop guessing, connect a scanner and read the live OBDII DATA.... Philip
darkestskydiver
3.8 & 4.2L V6
Mar 20, 2013 06:08 PM
darkestskydiver
Aerostar
Mar 20, 2013 02:27 AM
monkeyspain
1997 - 2003 F150
Jan 5, 2013 08:30 PM
73F100*8Mile
Dec 9, 2005 08:10 PM
