351 cleveland problems
Old Jun 26, 2011 | 12:09 PM
drof46's Avatar
drof46
351c with torker intake 4v closed chamber heads. New edelbrock carb, new plugs, new wires, malory hei distributor, high volume mechanical fuel pump.
I had a holley carb and it idled fine but stumbled under load. Pulled it off and put a new elelbrock carb and there is no change. Idles fine but when I attempt to drive it stumbles. I bought this engine rebuilt and have put 161 miles on it. Bought from an individual so there is no warranty or return. I have no idea whats going on so any help is appreciated. Could I be running on 6 or 7 cylinders under idle and once those cylinders are actually needed its just not enough to move my truck fast? I filled it up with premium fuel so I don't think octane is the issue. With the holley on it would blow liquid out of both sides of the exhaust. I thought maybe it was dumping too much fuel and that is a major reason I put on the edelbrock yesterday. Prior to putting the valve covers and intake on the engine all the valves moves easily when hand rotating the engine so I don't think I have a stuck valve issue.
Thanks
Old Jun 26, 2011 | 03:09 PM
wyoming4x4's Avatar
wyoming4x4
what distributor?
Might be a distributor doing something weird. Do you have 12+ volts to the coil? ran into this with a older bronco once and a resistor wire situation. catch you later and will check back in later.
Old Jun 26, 2011 | 06:09 PM
drof46's Avatar
drof46
I'm thinking of getting a compression tester just in case. It ran fine in the beginning (last year). It was in storage for almost a year so I'm going to go ahead and drain the gas tank even though most of the fuel in it now is new. Just in case its a gas issue.
My wife thought she was going to die when I asked her to hold a plug wire with a plug in it and watch for a spark. Needless to say, it had spark.
Old Jun 27, 2011 | 08:59 AM
mark a.'s Avatar
mark a.
Define stumble ? Does it backfire ?
Old Jun 27, 2011 | 09:19 PM
drof46's Avatar
drof46
Yes it will give a small backfire, not the load shotgun back fire, but still noticable. Are you thinking timing?
Old Jun 28, 2011 | 11:13 PM
kevin316's Avatar
kevin316
Timing would be my first guess. What do you have for advance at an idle and what do you have at about 3000 rpm?
Will it rev ok if there is no load on it?
78 f150 400
Mar 10, 2017 12:06 PM
53fatfndr
Aug 3, 2016 10:36 AM
palmrose2
51
Jul 18, 2016 08:20 AM
blake8105
Nov 30, 2015 06:10 AM
ToTheFloorToGo
May 3, 2008 10:52 PM
