Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Transmission Guides
- How to Check Your Transmission Fluid
Step by step instructions for do-it-yourself repairs
5.0 LITRE TRANSMISSION DIPSTICK GONE?
Pics of the 09 6 speed trans dip stick. - F150online Forums Should be there unless they changed it again
The 2005 Mustang GT with the 5 speed auto didn't have a dipstick either. Far as I know, Ford is removing "owner" checks for the transmission in nearly all (if not all) their vehicles. I don't think it's a good idea, but according to a service rep from Ford that I talked to about a year ago, he said that factory studies of owner maintenance habits indicated that only about 3% of owners checked transmission fluid and they could save nearly 1.5 lbs by removing the dipstick, so they went to a system of checking similar to the rear end: 2 screws, remove the top one, and fill it till it leaks back out, to drain, remove both. In 2010 the only F150 engine that had a transmission ws the 4.6L 2v (4.6 3v and 5.4 did not have a transmisison dipstick.
If I remember correctly, on my 2010 FX4 transmission fluid change is recommended at 150K miles in normal service and in towingl. In 2011, the 4wd is also 150K normal and towing. Hmmmm Wonder what happened to the "severe service" increased change interval? The oil change interval is 5K with severe service, but transmission remained the same ?????
It not only saves on weight ,but if what i saw about ford selling 150,000 f150's a month is true ,it is also saving them a bundle on parts and labor to install it. The same holds true for some of the wiring harnesses in these trucks . certain models will have wires run in the doors to accomodate pwer mirrors and such and some dont. If they delete 8 ft of wire in 75,000 trucks per month that also would save them a bundle of cash, especially with the high price of copper. Its all about the bottom line, and the bean counters are all over that.
I'm guessing that in addition to saving money and a few ounces of weight, that allowing owners (or ignorant mechanics) to check fluid and get incorrect readings if they don't run the engine, etc, has caused overfilling of transmissions, addition of the wrong kind of fluid, etc, and might have actually caused more problems.
I am not a fan of removing owner access to fluid levels; BMW has eliminated engine dipsticks on some cars, and I would simply not buy any car that relies on electronics to confirm that my engine is full of oil or to make it more difficult for me to do my own maintenance.
George
George
True , but all that they have accomplished is to make it harder for the owner/ignorant mechanic to check that fluid. I agree with you though had i known there was no dipstick and that i would have to rely solely on the electronics to monitor my fluid level , I may have chosen another vehicle to spend my money on
Talking about eliminating items from new cars. Several car makers have eliminated spare tires from certain models such as some BMW's, Hyundai Sonata and 3 GM models.
They say it saves an average of $22.00 per car plus a bunch of weight. Some high end models offer run flat tires and others offer a flat repair kit.
What kind of BS is this!!!? Vehicles are at an all time high with lower rebates and incentives than in recent years and they're pulling this crap?!
Perhaps it's time to go find a 1980-1996 F-150 with a 300, spend the money to make it new and drive the hell out of it for years to come.
Ford has made things more diffucult, but you can still check the fluid level of your transmission. It requires that you access the dip stick from under the truck, but it is most certainly something that you can still do. It's just a hassle.
I will see what I can extract from my pdf'd service manual.
