Been sittin' a while...help
Old Jun 25, 2011 | 08:29 AM
92bruiser's Avatar
92bruiser
I have a 92 F250 7.3 IDI with 60k. I bought this truck cheap, it was not running when I bought it. I was told the only thing that I needed to do was replace the fuel lines and some minor clutch work. The truck has been sitting for about a year. Besides the the fuel lines what else should I look for?? The brakes and brake lines are all new as are the fuel tanks and sending units. Thanks
Old Jun 25, 2011 | 09:39 AM
84-6.9L's Avatar
84-6.9L
Get and injector install kit, it will have everything you need to replace thre return lines on the injectors (I'm assuming these are the lines you are refering to).
And what do you mean by minor clutch work? If you have a DMF (dual mass flywheel) you may be in for a fun time they are hard to get and expensive, alot of members here have switched to the convetional SMF or sigle mass flywheel.
As always more info would help answer you questions the best
chaser1602
Feb 13, 2015 07:40 PM
92bruiser
Oct 1, 2011 04:44 PM
a79fordman
Jul 31, 2011 12:18 AM
mholm8
1983 - 2012 Ranger & B-Series
Jun 25, 2007 12:13 PM
Chris92
Aug 31, 2005 12:32 PM
